It is currently Mon Jun 23, 2025 9:17 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Fri May 10, 2013 7:44 am
What a beauty - what a beast :-)
Great project that will be followed with pleasure!
Daniel
To Victory and beyond ...
PostPosted: Fri May 10, 2013 3:48 pm
Here's one for the books: Another one of Jimbo's masterpieces and it WON'T have a shot at a medal at Telford: Too little plastic on this one!
Beautiful work, Jim! Can wait to see you get on with it!
Guido
AKA "Tailor"
VMF'06 - German Gamblers
PostPosted: Sat May 11, 2013 4:32 am
Starling Models
Starling Models
Guido
Ah, but if he had used this build as a master, then made a resin copy of it, say something you could make a kit out of and then built it from that, then it would.
Mike
Starling Models
http://www.starling-models.co.uk
PostPosted: Sat May 11, 2013 5:19 am
Could be, he does not want to reinforce the flooring under his metals cabinet.
Harry
BattleFleet Kits, PE & Decals
Alliance PE & Kits
Orange Hobby
Lifecolor Naval Paints
Testors Naval Paints
WEM
ABER Barrels
Atlantic Models PE
LionRoar PE
ModelArt
Available from our Online Store
http://www.battlefleetmodels.com
PostPosted: Sat May 11, 2013 7:15 am
Fair point all of the above..although the proportions of plastic are not entirety set in stone...
( Gordon Brookes sad disqualification with the SS Sagamore was a consequence in there being absolutely NO plastic on the entire model!! ( purist! :thumbs_up_1: )
Mark Slotas models are not always entirely plastic=--
in any case I was planning to pop it into the sail category :cool_2:
UK IPMS definition of scratch
( Scratch built (S) - A model constructed where the main body parts and / or flying
surfaces are home-made or vac-formed plastic, other than of a commercial nature.
The basic structure should be of plastic although a supporting (wooden) core is
permitted. A scratch built model may be detailed to any level desired by the
modeller.
UK IPMS Competition Telford Class Sail
Class 68 Sailing Ships (any material any scale)
question is ...-- on Agincourt... are the sails auxiliary or is the steam engine auxiliary ?
They are really true motorsailers ... although
by definition a long passage on Agincourt or her most contemporaries was always conducted under sail ( Back in those days ....labour was paid for, time they had and wind was free)...
anyhow-- lets see if I can finish the model to a satisfactory standard... :wave_1:
Tara
JB
PostPosted: Sat May 11, 2013 7:41 am
OK gentlemen....
With the hull at the stage it is at it could still be cast.-- ( and perhaps even marketed via FWL )
It would be merely a starting point ( in the vein of the craftsman kits )
However it would still be a semi-scratchbuild for spars,detailing of deck fixtures, and outside sourced tubing for funnels, PE ratlines, ships boats et al...
IF there is any interest in this... :scratch: at all I might consider the idea of temporarily stopping the build once the hull is near completed to allow it to be moulded and cast....
Bear in mind this is not a Hi-Tec CAD rendered design but a hand carved hull--so it may not have the precision of a 'professionally' produced kit such as Combrig ....
Register your interests and thoughts here!!
Jim Baumann
PostPosted: Sat May 11, 2013 9:57 am
JB, the funnels in your photo look to be pretty straight forward. I could make a set ready for casting a day or two.
Harry
Alliance PE & Kits
Orange Hobby
WEM
ABER Barrels
Atlantic Models PE
LionRoar PE
ModelArt
PostPosted: Sat May 11, 2013 12:02 pm
Jim, maybe it's blasfemy or a pure eretic thought...but, if id be in your shoes,i'd make a resin copy of the hull just to build agincourt as coal barge...those cranes screams for being modeled :D:D:D
(by the way, greeeeat work so far, i'm waiting to see this finished)
PostPosted: Mon May 13, 2013 4:34 pm
Watching this thread with interest, Jim. :cool_2:
Is this your first full scratch build? Or are there other efforts in your past? This is really inspiring me to get back to the Solferino, which I hope to do soon. Keep up the good work! You are an inspiration to us all. :wave_1:
Pessimists see the world as it truly is...
Optimists change the world.
PostPosted: Tue May 14, 2013 9:27 am
Thank you all for your encouragement. :wave_1:
The bow has now been shaped and contains a stainless steel stem piece
I shall re-coat the hull with fresh paint to homogenize and eliminate any further surface defects...
then the decision has to be taken whether of not to try an make a kit ..........
from the main forum
So far this looks like we will need at least 18 hulls. :scratch:
Nevertheless- I hope not to mislead anyone --this is likely to still be a ' Garage ' kit- at best...
-requiring quite some scratch-building of guns,small structures etc etc, adding of windows doors etc... making Pinrails to surround the masts and of course making your own sails.
I will be making some moulds for the sails--so as to be able to shape and stretch wet paper over them
all of this still needs a bit of experimentation.
If that works then perhaps I can get some cast.
The PE I envisage will include the ratlines -size and layout specific to these ships - mast platforms,bridge walkway platform , admiral stern walk platform and railing--and hopefully also the roof.
I thinks PE will be too thick for the racers of the aft sternchaser gun...-- so will see if I can 'let in ' some depiction of this into the deck before it gets cast
I am hoping to get a PE Bowcrest and semblance of scrollwork also
I am in touch with metal turning people for spars, topmasts and barrels .
Will keep you abreast of the project...
what have I done... :doh_1:
Jim Baumann
PostPosted: Sun May 26, 2013 12:06 pm
OK--time for an update:
The status quo on this ' craftsman type' - "starting-point-only " kit is:
1) The hull has been completed as far as I want to take it and is getting packed to be sent away for casting
I have added the 'over-the-side' heads as well as the outer edged of the hammock through as well as a few small adjustments.
The hull has been sanded fair and smoothed
ie there are no deck structures or funnel bases-
-I prefer this anyway as these are easily fabricated from strip styrene-
==> that way one gets far cleaner paint demarcation twixt deck and structure.
There are no bun carriage races on the deck--as I fear getting these cast dead sharp--leave along painting retrospectively would be very hard.
I would anyhow prefer to add these retrospectively of flattened copper wire anyhow ( as I did on Vladimir Monomakh)
http://www.modelwarships.com/reviews/sh ... /index.htm
2) The PE is in hand with the designer--this will include the sternwalk floor, railing and roof, all ratlines-upper an lower -upper and lower tops(platforms) for all masts, all skylight lids, engine room slotted vents, bow crests ( for both Agincourt and Minotaur allowing both ships to be built as well as a few other useful parts
3) Being a full rigged ship on fours masts there are a lot of spars--I intend these to be of turned brass--a supplier is still to be finalized upon.
Here are a couple of images of the completed hull master.
PostPosted: Sun May 26, 2013 3:26 pm
Looks great Jim
PostPosted: Mon May 27, 2013 12:41 pm
hello Jim
I'm always amazed by the smallness of hulls upon which you are working :thumbs_up_1:
I persist, you are a E.T
congrats
Nicolas
PostPosted: Mon May 27, 2013 3:02 pm
Sorry, couldn't resist. :big_grin:
