Since my last post, all 20mm guns have been added to the model now. There's about 45 of them around the ship.
Also..........
Planes are done for my Iowa carrier conversion model. I didn't make that many of them as I only wanted a "sample" of different types on the flight deck. They're not detailed with squadron numbers or other markings since a real Iowa carrier was never built and it would have been unknown what squadrons and such a ship would have had. I tried painting the aircraft weeks ago in the 3 tone blue/gray scheme common to most US Navy carrier aircraft, but it was proving to be a bit too difficult, so I just went with an overall gloss Dark Sea Blue which is what the Navy was changing it's aircraft to later in the war. The Avenger in the upper right corner has a spinning prop and this aircraft will be situated near a catapult on the carrier model.
4x Avengers in the top row.
4x Helldivers in the third row.
4x Hellcats in the second row.
4x Corsairs in the bottom row.
Started the white dashed line flight deck markings earlier in the week. Wish me luck.
Bad thing about these decal markings from the Trumpeter USS Franklin ESSEX kit is that the dashed line decals are about 3 ½ to 4 inches long. There are 20 of these dashed line decals to apply, but I've never been good at laying down very long decals. So.........I have to cut each decal down further into smaller 3/8 inch segments. Not fun.
Then hopefully try and make sure each end matches up correctly to another end of another piece of decal when I lay these down. Probably won't be done with these till end of January. Gonna be a long slow process.
Starboard side dashed white line done. Wasn't easy. Will start the port side this weekend and hope to be finished with that by Sunday. I'm going to skip adding a center white dashed line down the center of the flight deck. Port and starboard lines is enough for me.
