Columbia's superstructure is now filling up with PE particles, after the sanding of the styrene parts. I can't place some antennas on the stacks. I also need to wait for the wooden deck to place some superimposed parts, the base needs to be painted first. And there are some differences between CL-56 and CL-62, that implies some scratchwork.
I made the secondary gun directors.
The Mk51 directors each got a fragile PE part that breaks when added to the plastic.
I keep the masts on hold to avoid damage.
A complicated bending diagram is shown for the Mk8 primary gun control radar.
The manual can be found at
http://www.researcheratlarge.com/Ships/Misc/FCR-Mk8/ and you really need this drawing to understand how the part is bent. It can't be made perpendicular so it needs to be cut in half.
With the Mk8 the Columbia should now be able to range in on large targets at 50.000 yards (or 143 yards in scale...).
Some ladders are added to the conning tower.
The stacks get some internal PE, but these tubes tend to crack while being removed from the sprue.
The PE under the stack platform will be placed over the railing near the stack, but this is PE is wrong in the kit so I first need to find out which part will be left over in stead.
There are almost 1/10 as many small triangles as in Zuikaku. That's saying something.
I still wanted to integrate these small PE grilles.
Drilling small holes and connecting these while drilling.
This is the aftermost part of the superstructure, after filling in the seams with putty.
Now with the rangefinders on it.
Strange how the mast holes don't line up. I had to correct the lower hole.
Dry-fit without railing.
Some railing is now added, but not where the wood deck has to come.
ABSD is now shadowed with some German Gray. The small triangles keep falling off, some are now lost.
The midships barbettes are now superdetailed.
Small sinkmarks are riddling these and other kit parts. Here sanding would be difficult.
I was spared this by the extension kit.
Even the underside is impoved.
The magazine holders are a nice touch.
Some are misnumbered though. Part C2 is not needed on the deck barbettes in this sprue, but in the round barbette on the cilinder.
These are added and get some inclined ladders. But those are difficult to bend because of the small steps.
This image shows how Columbia differs from other Clevelands. The barbette after the second 5 inch gun has a rectangular base. In another topic I read the explanation:
http://www.shipmodels.info/mws_forum/viewtopic.php?f=48&t=34416&start=360Quote:
Cleveland had two twin 40mm guns port and starboard on the O4 level of the forward superstructure just aft of the main battery Mk 34 director. It also had two twin 40mm port and starboard on the O3 level of the aft superstructure about even with the Mk 37 director. Columbia kept the two twin 40mm on the aft superstructure but the forward pair were replaced with two Quad 40mm on the O1 level just forward of midships.
But on this 1945 picture, I'd say both of these look like doubles. I could be wrong and you could see double barrel pairs.
At last the secondary gun director radars are added. But we denn't need the orange peel, that's 1945 Birmingham.
So the long turned radar axle is replaced with a wire.
