Thanks, Martin! Some more changes follow in this update.
I noticed the added foil was loose at the edges. To ensure it to properly adhere to the plastic, I clamped a metal object to it and poured some Zap under the edge.
The starboard edge where the island sits, slightly deviates to the bow. This is according to plans, but the hull doesn't fit to the deck like that. Also, if the island is aligned to that, the stack would not be parallel to the keel.
So I cut it along the hull line and rounded the rear part again.
The tie-down-like things and other removed deck parts were added again. I made the planking foil to tight and I had to add a metal strip to both sides. Some filing was needed to level that strip.
Before fixing the deck, I made sure stuff can't fall in the elevators and disappear. I walled off the open holes with some leftover foil parts that were painted grey, I know there were fire curtains in the hangar. Then the main part of the deck was glued to the hull with some clamping.
The extremities are fixed later on with superfluous styrene glue. The deck was too stubborn to risk CA glue.
The 1935 changes to the ship were not all provided in the kit, so I had to make an important addition to the front deck edge.
In this 1936 picture the changes under the flight deck can be seen.
First the bracing under the girders had to be sawn off. This risky undertaking was almost done when the entire girder was knocked away. It was put back where it belongs and the stumps were filed.
Drilling the holes in the plating could be done with the Proxxon, but I hate to clamp the parts. I could manage it with the Dremel.
The 5 plates were then glued between the posts. There was a working space inside. I don't know if I can add a floor between them, there is a telescopic mast going through.
