It is currently Fri Jun 13, 2025 2:01 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Mon May 24, 2010 9:23 am
This has come along wonderfully and while no doubt you'll get this finished sooner then later, don't forget those scratch built mast you said you'll talk through, also the close-up shots of your work. :thumbs_up_1: :thumbs_up_1:
PostPosted: Mon May 24, 2010 9:56 am
I agree. Unless you are trying to depict heavy sea use and long intervals between refits, weathering should be more subtle on a new or well maintained ship.
PostPosted: Sat Jun 12, 2010 9:51 pm
Location: as far south as you can get before you run out of planet
Just seen this build in the flesh at our local IPMS meeting and it is looking great.
:thumbs_up_1:
The whole problem with the world is that fools and fanatics are always so certain of themselves, but wiser people so full of doubts.
Bertrand Russell
PostPosted: Fri Jul 09, 2010 8:57 am
heres some more pics. Having to learn how to make a sea now so ignore that its still just experimental. The ship is however pretty much finished.
I used Caenis line for the rigging and gum glue. Using our own David Griffiths technique. I cant recommend his book high enough. Vertical rigging patched on with matt varnish.
Weathering was with oils. Black, burnt umber, white and blue. then pin wash with a near black brown around detail .Then dry brush with oils. I think it came out ok and Im now a convert to this technique . Even though its very time consuming.
The signal flags incidentally are A M for my initials :) couldn't resist. Flags are Lion Roar . Fixed with dilute white glue. Incidentally these decals wouldnt stick togeather. I had to use a white glue solution and stuck them to foil. This allowed me to bend and pose the flags.
Alecap, all I can advise in mast building is this. For a start you need a high mag desk lamp or optivisor ( well you do when your in your 40's. lol ) Id recommend good tweezers. I use the tamiya stainless steel ones for precision work. and Vernier calipers for measuring ( essential I think ), particularly with the cross struts.Medium superglue. I got the thin brass from pacific front . I think the cross struts are 8 thou and the main struts 14 . I think Ill have to check. you need a steady hand and patience. Use a lot of eye ball checking for symmetry as you work . A word of wisdom , dont trust the dimensions of the kits masts. In hindsight I would re do the rear mast. but thats a long storey. Get as many photos of the real thing as you can. Oh , if you want a world of pain try soldering the masts. I did that for the main frames. This uses lay on joints and its a whole subject in itself. I do think it adds structural integrity to the masts. Some structures such as the flag bearing part of the rear mast couldnt possibly be glued in place. solderings the only kind of joint that would hold it in this scale. Im sure Ive missed stuff. get back at me if youd like more info. Remember this is only my second kit so Im a beginner myself ;)
More to follow as I finish the sea. The rigging needs its insulators and I may add 2 boats at the front. The large whalers are often missing I see in pics so Ill leave those off.
Untill next time.
Your feedback is very welcome :)
"The vast majority of Iraqis want to live in a peaceful, free world. And we will find these people and we will bring them to justice."
Washington DC, 27 October, 2003. President George W Bush
PostPosted: Fri Jul 09, 2010 9:39 am
last pic just to give some sense of scale :)
PostPosted: Fri Jul 09, 2010 10:35 am
Very, very well done!!!!! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Bob Pink. :wave_1:
PostPosted: Fri Jul 09, 2010 5:05 pm
She is looking very good :thumbs_up_1: Nice work
Bertrand Russell
PostPosted: Sun Oct 03, 2010 7:22 am
Ill have to put up some new pics of the finished ship now.
I just won the New Zealand IPMS Nationals with this build. Thanks to all of you out there who gave encouragement and helped me along the way :)
PostPosted: Sun Oct 03, 2010 11:59 am
Congratulations!
I just discovered your WIP and like it :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: .
It is valuable for me: Just before I discovered it I decided to start a small 1/700 project with a small IJN destroyer and after some research I found the Matsu class and its derivates and ordered two models (Pitroad Kaki and Tamiya Matsu Destroyer).
I think you never mentioned the model you used as a base. Is it the Tamiya IJN Sakura?
Dirk :wave_1:
Dirk
http://www.modelshipgallery.com/gallery/users/Dirk-Ponge/user-index.html
PostPosted: Sun Oct 03, 2010 8:39 pm
Yes its the Tamiya Sakura. It was a bit basic out of the box as you can see. was a fun build. I really learned a lot in the build process :) I hope you put a build log up. It really can be a lot of fun.
PostPosted: Fri Dec 24, 2010 3:00 am
And finally its in the gallery now. Pics are a bit better but the color saturations still a little off. Weathering looks more red than it actually is in real life. Ce la vie.
Any comments very welcome.
Now working on the Fabuki class. Bring it on ;)
PostPosted: Tue Dec 28, 2010 9:52 am
An outstanding build, Allan, and a worthy champion. :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
PostPosted: Tue Dec 28, 2010 10:50 am
Allan, I just discovered your WIP thread. Outstanding work! I don't think anybody looking at that would believe it was only your second ship build after a 20 year hiatus. I'm a returnee to the hobby myself after over 30 years away and there's no way I would have tackled a build like that in 1/700 as my second project. I second what another poster said above about the weathering. Very nice, subtle, not over done. You can be justly proud of you work. I can only imagine what your future builds will look like as you gain experience and knowledge. I'll be looking for your work in the Gallery here.
Bob
PostPosted: Sun Jan 02, 2011 10:12 am
A Nice build there :thumbs_up_1: The weathering looks spot on to me something I have to tackle on a build I got going(aero guy) of the Graf Spee.Congradulations on the IPMS placement.Cheers Kevin
Twain:Ethical man - a Christian holding four aces
Twain:Life would be infinitely happier if we could only be born at the age of eighty and gradually approach eighteen.
