It is currently Sat May 10, 2025 9:01 pm
Post new topic Reply to topic  [ 410 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 21  Next
PostPosted: Fri May 23, 2014 8:37 am
anyahajobuzi wrote:
Thanks Jon!
The color is Humbrol 66.
Are you building these little guys too?
Cheers: Laci
Hi Laci
Thanks, I like the Humbrol paints as well. I have the resin WEM set that has two and then what came with my LHD.
Too many projects, not enough time. :-)
http://www.f-16.net
http://www.c-130.net
Building:
1/48 Lancaster (HK)
1/350 Akagi
1/350 IJN Kongo
PostPosted: Sun May 25, 2014 8:27 am
[/quote]
Hi Laci
Too many projects, not enough time. :-)[/quote]
AMEN! There just aren't enough hours in the day.... But if we lived on Mars.... :smallsmile:
Good luck Jon
By the by, some of the planes in the airwing are shaping up, I should have the first Sea king done really soon
Cheers: Laci
PostPosted: Mon May 26, 2014 3:30 am
Yeeeeeeeeeahhhhhhhhhhhhhhhh! The first aircraft that is actually part of CVW-8: I am done with one of the 3 Sea Kings.
Put a lot of work into it, and I swear it looks better in real life , than on these awful close-ups....
But here we go. A lot of thing had to be scratched. Even some of the PE pieces were heavily modified. Now I wish I actually put some equipment in the inside of the chopper.That open door leaves a pretty big (empty) opening...
Happy modeling everyone!!!
Cheers: Laci
PostPosted: Mon May 26, 2014 3:58 am
Holy crap, dude! :cool_1: :woo_hoo:
That helo sure has been through the mill...almost ready to be tossed over the side or put in for a total rebuild...
On the ways:
1/200 Trumpeter HMS Nelson
In the stash:
1/35 Italiari PT-109
PostPosted: Tue May 27, 2014 3:22 am
Stunning!
Looking very good!
PostPosted: Tue May 27, 2014 11:59 am
Wow, look impresive
Beautiful Girls in your city
PostPosted: Tue May 27, 2014 1:02 pm
HI Laci
as always,a work very impressive!especially given of the scale :worship_1:
cheers
Nicolas
PostPosted: Sun Jul 20, 2014 2:51 am
Sorry about the very late reply to those very kind words! Thank you very much! Especially Nicholas, since we are all aware of your super-natural skills, man!!! I am not taking these words granted, I just had been extremely busy with work, my mother-in law visiting from Hungary (and whom I actually like, despite her being a mother in law:)), plus it is kind of summertime and like so many of you, I like to get out of the house. And in doing so I happened to go thru some pretty awesome adventures, one of them particularly related to model building! Definitely more on that at the next post!
These days the weather in the Yukon is kinda sucky, so I did labour away at the Airwing.
Well, as usual, I am not making it very easy for myself, but I think the results are worth the Arthritis.....
Continuing with the more complicated types. The ones that need the most scratch-building, and improvising. These are namely the Seakings, Greyhounds and Hawkeyes (and later on the Tomcats).
I have the Greyhound completed, and I figured I got enough to write about, despite the E-2s only being half finished...
HERE ARE SOME POINTERS TO THOSE WHO ARE WISHING TO ACHIEVE A BIT MORE REALISTIC PLANES THAT WHAT THE MANUFACURER PROVIDES:
I think the Trumpy Hawkeye is way better than Tamiya's. On the other hand their Greyhound is pretty bad ( but it's the only one in the market). The engine/main gear pod of the C-2 is garbage. So is the wing, and the vertical stabilizer. All the right parts can be obtained from the E-2s. Picked a very colorful squadron for the Greyhound, and I only noticed the wrong shape of the vertical stabilizer, AFTER I decaled it, so it will remain the incorrect shape. In reality this part is the same as on a Hawkeye.
-I figure WEM did a better job at the photoetch than TOM's, although Tom's main landing gear struts are way more accurate(but I didn't have enough of those).
-The main wheels are from Tamiya, but to get the perfect size wheels for the nose gear I happened to use surplus 1/350 Trumpy Dauntless wheels...
-This is a good time to mention that the C-2's nose gear is arranged differently from that of the Hawkeye!
-The panel lines are a touchy subject in this scale I think. Just like I don't think that the flightdeck should have "anti-skid texture", neither should the airplanes have panel lines in 1/350. Not to the Trumpeter effect, anyway. For this reason I used the radardishes for the E-2s from Tamiya. I should have filled those lines in on the wings as well, but to be honest: I got lazy....
-on the leading edges I made sure I made the black leading edge boots seem like they are 3 pieces, not just one black line. I used thin decal lines again to "separate" them, just like I how had been using that trick for the window frames.
-Don't forget about wire-antennas and other details hanging off these planes! And the copper coating on the side windows on the Hawkeye. I lucked out and managed to make it, so it is see-tru from the side, but copper from any other angle. Pure luck....
I think this is all I can think of to point out. I hope you guys like what I did with the subject. Of course the photos bring out a lot of mistakes, this is how I noticed some of them, so I got to back to fixing stuff up.....
Another thing that I could have done differently: painting both TOP and bottom of the ailerons white. But I found enough photos showing the top grey, so I didn't correct it....
I finished another Seaking too (well 99% complete) and I also found one of my old Seakings from my Enterprise from like 12 years ago.....:)
Well, I hope you guys will like the tiny little planes the way I finished them. I also hope everyone is having an awesome summer. I am sure you all are because aside from Doug and Jim, everyone's project have slowed waay down:) mine too though
Cheers: Laci
PostPosted: Sun Jul 20, 2014 5:30 am
Amazing ... I have really to remember that these tiny planes are 1/350 and not bigger in scale! Great job! :wave_1:
PostPosted: Sun Jul 20, 2014 6:37 am
Amazing ! :thumbs_up_1: I have been so inspired by all the way awesome carriers here that I have got my own Nimitz on its way :smallsmile: ! Soooooooo I will definitely be after as much help as you guys can offer :thumbs_up_1:
Jenny :wave_1:
PostPosted: Sun Jul 20, 2014 7:15 am
Truely amazing build so far, I should get back to my carrier again, just been pre- occupied by doing animations that really is a time killer. Well done!!!
Jacques
Currently working on:
1/350 CVN 65 - Project Enterprise
http://www.shipmodels.info/mws_forum/viewtopic.php?f=59&t=210966
PostPosted: Sun Jul 20, 2014 10:56 am
Those are surely the best finished 1:350 aircraft I have ever seen - by quite a margin!
You have set a new bechmark of excellence in aircraft in this scale in my opinion.
PostPosted: Mon Jul 21, 2014 7:41 am
Welcome back Laci! Awesome job on the Aircraft man, really. You have way more patience than I do for those things. I am happy with mine, but you and Doug take the AC to a whole different level.
PostPosted: Mon Jul 21, 2014 3:53 pm
Hello Laci!
It's good to "see" you again! I hope you finish the ship by the end of the year and you can bring it to Móvár in 2015.
Non sibi sed patriae
PostPosted: Mon Jul 21, 2014 8:10 pm
I'm done with modern carriers. You Ryan,Doug,Kosta and a few others. You guys can take over I'm building my 1948 1/350 Coral Sea. By the way outstanding work as always. :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
PostPosted: Tue Jul 22, 2014 4:14 am
Hi Laci,
Love your work in progress, the work you are doing with the airwing is amazing, following with great interest :thumbs_up_1:
PostPosted: Tue Jul 22, 2014 8:48 am
Hey Laci! Good to see your still kicking up there in the frozen tundra! Those are some sweet looking aircraft dude!!! I really like the weathering and paint "patchwork" on them as well. Those little babies are gonna look right at home on your super detailed Nimitz. Can't wait to see the rest of the airwing too. Very nicely done, and keep that good stuff coming! :thumbs_up_1:
Doug
Currently building:
http://www.shipmodels.info/mws_forum/viewtopic.php?f=59&t=120496
PostPosted: Tue Jul 22, 2014 12:24 pm
Thanks everyone for the compliments, I try not to dissapoint. Plus there are sooo many other talented modelers here, that they are pulling me forward.
-RED: I'd love to build an older "modern" carrier. I'll build your Coral see...but then I am keeping it! :big_grin:
-GABOR: yeah 2015 Movar is the plan....I just wish Movar was located in Arizona or Hawaii, so I could get a hot holiday out of it..Or that they hold the competetition in July instead of April... :Tirade:
Thank guys, and happy modelbuilding everyone!
Cheers: Laci
PostPosted: Fri Aug 15, 2014 4:23 pm
Hi there flattop-lovers! I see everyone is taking a break, enjoying summer and whatnot. (Except Jim with his Naval yard. That guy is serious about having fun :big_grin: GO JIM!)
We don't get summer this year in the North-pole, so I am working on tiny Tomcats (no pictures until they are done he-he) . But I have a commission for someone (potencially high-paying) Does anyone know anyone who does very custom made decals?
Thanx in advance!
Cheers: Laci
PostPosted: Fri Aug 15, 2014 5:48 pm
:lol_pound:
Well Laci somebody has to keep the mojo going while everyone else is out for summer breaks and vacations......
I'm still plugging away at my diorama, I've been planning materials and kits for phase 2 which is mostly the airfield, I've been inventorying the aircraft I have on hand and what I still need to order. I am also working on the layout for the runways and taxiways, trying to figure out the buildings and everything else I'm going to add. I have figured out the runway and taxiway lighting, I'm using 0.5 mm fiber optics. So, that's going to be fun to work with, wish me luck.
Now get back to those aircraft......................... :thumbs_up_1:
Jim Varnell
ABH2 USN/RET.
89-00
Eastern NC Modelworks
Up coming projects:
(Table 1 underway)Feb.2017
Users browsing this forum: No registered users and 44 guests
