Got a lot done this week, here's some photos:
I repainted almost all the deck fixture bases by hand with the new grey color; it might just be me but the deck doesn't seem so "cutout" looking now as I was able to bleed tiny amounts of paint into the very tiny gaps between the deck and fixtures and bring it all together nicely. I plan to make black "metal" rims with rivets out of styrene and dry transfers to put around all the turret bases like the real thing as well.
I'm at the tail end of erasing the only real superstructure seam from the deck level to the bridge area up above:
I also started detailing the first level of the superstructure on the aft portion that I've spent way too much time wrestling with:
The "eyebrows" are from the KA set; I simply cut them off while being careful to leave a tiny "T" of the PE porthole rim at the bottoms to represent the brackets that were used to hold the porthole shield shut:
I made the doors out of styrene strip and have been trying to figure out a relatively easy way to add the wire conduits (which were only molded onto some places on the kit and frustratingly been ignored in all the aftermarket sets to date, even though they would be
really easy to do with PE
. In this case, I tried PE; since I already have most of the funnel rails in triplicate from buying extra stuff, I trimmed down the protrusions on some extra pieces, bent and glued them back to back to get a fairly decent conduit line... though it came out a bit sloppy so I'm not sure if I want to keep it.
BTW, what happened to the rest of the Big Bissy Builders club? Everybody else who is building one went silent. I'm frightened and alone!
