2011/2012 USS Dwight D. Eisenhower in 1/350
NWarty
Re: 2011/2012 USS Dwight D. Eisenhower in 1/350.
Post by NWarty »
Looks fantastic James! :thumbs_up_1:
~Blake
Completed:
1:350 Trumpeter CVN-68 Nimitz, "Eagle Claw"
Planned: Nimitz fixes and sprucing up
boomstick68
Post by boomstick68 »
With the exception of a couple sections of railing, the transom bay is done. Now on to the rest of the hull so I can shoot her with some gray skin. And then.......the hangar bays. :woo_hoo:
youngtiger1
Post by youngtiger1 »
Ok, I guess your going to have another follower here. It looks like your using Trumpeter Nimitz as a base for your project...sorry not fully familiar with ships. Well, keep up the good work. :thumbs_up_1:
Mike
boomstick68
Thanks youngtiger. So, all STB and Port side bays are complete. I will move on to the weapons sponson's details next.
NWarty
Post by NWarty »
~Blake
Completed:
Bigdaddy Mark
Post by Bigdaddy Mark »
son of a gun does that look great!!
~ Chester W. Nimitz ~
boomstick68
Thanks Mark. Well, trying to get the hull finished, I started final work on each of the weapons sponsons, starting with the port RAM launcher. Flight deck is just temp placed to check alignment. I also, like I always seem to, need to touch up where the anti fouling red bled through the mask. :censored_2: :mad_1: :Mad_5: :Mad_6:
boomstick68
All the detail parts/weapons for the sponsons have been completed and put aside. I now have her mounted on an assembly stand in preparation for the hangar bay construction. I will spend some time in there, probably even throw in a 1/350 kitchen sink.
:cool_2:
anyahajobuzi
Post by anyahajobuzi »
Great to see you back at it James!!!!!!
Those RHIB sponsons look GREAT! :thumbs_up_1:
did you make those life-rings, or are they aftermarket? (maybe North star?!) or maybe your great skills?
all your sponsons look great, give yourself a BIG round of applause! seriously, great job!
Laci
boomstick68
Thanks Laci. I've learned quite a bit by studying your Nimitz. The life buoy's are from a Gallery WASP kit.
boomstick68
Humble beginnings of a Nimitz Class Aircraft Carrier hangar bay. I am not a fan of cutting out the poorly rendered hangar doors but it is prob the most important correction of this kit. Even if you close up the doors, it has to been done to create the compartment that is between the hull and the doors. What ever the Navy wants to call it. IKE's doorways are done, now on to the hangar walls. Someone asked me about materials used on the hangar and for me it's really simple. The walls are one inch high using Evergreen .020 sheet styrene with a top boarder of Evergreen 1/8" tile sheet for that characteristic square pattern you see on the upper portion of the walls. Various Evergreen products are used like I beams, rod, strips, square rod, and left over PE railings. The hangar bay may look intimidating but to me it's the easiest part of the whole ship, and the most fun.
A section of hangar wall.
boomstick68
Instead of decals for the flight deck I tried painting. Started with the characteristic resurfacing lines. Those will be toned down upon weathering. I have some touch up to do from paint bleed but I'm happy with the results of my first painted deck. This is just phase one of the process. I will be using varying shades randomly to try to achieve Laci's results on his flight deck. I can dream.
NWarty
Post by NWarty »
Awesome work James! I know that painting the deck is a pain but the results well worth it. Tamiya tape is the best stuff ever :)
Looking great bud!
~Blake
Completed:
anyahajobuzi
Tile board??! RE-surface lines?!?!?
James you are a genius! Although I hate you, because now I will have to build another Nimitz....a better one.
great ideas!!!! hats off!! Any ideas on how to make 50 tiny cockpits without wanting to cut your wrists and setting yourself on fire while jumping into the Grand Canyon with a chainsaw in your back (for extra weight)? (I am not looking forward to the airwing build... especially since Blake didn't just raise the bar, he took it, so I don't even know where it is... but it's probably somewhere extremely high.....)
keep it up James!!!!
boomstick68
Thanks guys. I can see that I may have to invest heavily in Tamiya tape. Great stuff indeed. As for an easy way to build tiny cockpits, I couldn't tell ya. I took the easy way out on my Nimitz with painted/decaled canopies. But now, with IKE, I'm in the same boat as you. I need to open up a bunch of bugs on this one. We'll jump together. :big_grin:
LE BOSCO
Post by LE BOSCO »
HI James
the bays of hangar doors are very convincing and the masking on your flight deck is superb !!!really good job :thumbs_up_1:
cheers
Nicolas
boomstick68
Thank you Nicolas. I have the flight deck decals in place and all sealed up with future. I know you guys are wondering what the hell I'm doing with all these stripes on the deck but there is a method to my madness I guess. I won't do any weathering on the deck until I attach it to the hull. In the mean time I'll resume hangar construction.
The real thing:
Lot's of weathering to do
boomstick68
Small progress in the aft hangar bay.
LE BOSCO
Post by LE BOSCO »
Nice small progress James! it promises :thumbs_up_1:
best regards
Nicolas
boomstick68
Thanks Nicolas!!
