I still had to replace the ABSD extreme platform with the smaller barge you see on the pictures.
Some staples attached to a piece of Green Stuff styrene and the outside is made.
These Normandy Rhino's show the topside texture I need.
To make this out of the staples, some engraving is needed.
A grid is engraved and two long staples are arranged around three rows of six short ends. These are filed to the exact length.
With all staples attached with some CA, more filing makes the top level out and it removes the scars on the flattened staples.
For a CL I need about 4/5 of the total number of wood blocks included in the ABSD kit, as there are two out of 10 sections that are not covered. It has more than 550, so 400 should do it. Because the ship will be connected to a lot of these blocks and I can't predict the movement of the hull on them during transport of the dio, I wanted each of the blocks to be pinned down.
A 0.7mm copper pin would do the trick.
Half of the pins were added here.
All of the pins I need are added, the removal of these blocks from the sprue is surprisingly hard. Strange how they chose to connect them sideways to the sprue, it's a lot of work to remove the burrs now. I only pinned 5 out of 8 sprues I drilled out, because I figured the outmost rows of blocks wouldn't be connected to the hull and they might be impossible to drill on the ABSD with the walls and catwalks present. Something to consider is that the blocks were not part of the construction, so the rust wash I'll do has to precede the assembly of the blocks. A few of them will get the copper thread protruding above the block into the hull. Then, with the ship fixed, the deck can finally be added to it.
To replace the freighter mast, I decided to use the wonderful range of AK Interactive brass pipes. They offer them from 0.2mm to 3mm with an interval of 0.1mm, so I had to order a series that I did not already own from other brands. I made use of the order to get me some MAIM 1/35 oddities, for other purposes of course.
Another unique feature of these pipes is the gross weight. I needed something between 2.5 and 3mm, so I ordered 2.8mm.
The first two measures I cut needed a filler tube to fit them to the center, but the AK one is so thick that it fits without one.
But this caused some interval in the top tube that made it sit crooked on the center tube. The stern mast is therefore sitting not so perfect.
The front one is even better. It would only be improved if I had used 2.8 on 2.9 on 3mm.
For the bow armament I had looked at the wrong pictures, checking out anterior C3 AP classes. These have a B-shaped platform.
For Bayfields the right shape is rectangular with a sphere inscribed to make room for a 5 inch/38 gun. I fit the L'Arsenal gun in it, and a second one on the stern. The platform will go on the forecastle after a base is added. I'm still looking where the ladders will run in it.
