1/350 'Nam Special Ops Carrier
- sgtryan13
Well, I have had this idea kicking around in my head for a while, so I decided to start in on it a little bit while I was waiting for the work on the USS GHW Bush to dry.
I had a lot of fun scratch building my WW2 what-if carrier, so I decided that I would do a similar project with the 1/350 Essex that was collecting dust on my shelf. I built the Essex kit when it first came out, when my skills were crude to say the least. Instead of junking it, I figure that the hull would be a good base for my idea.
The ship: My basic idea is to make a Vietnam era conversion to a what-if angled deck carrier specifically designed for Marine Recon and Seal operations. The carrier's main distinguishing factor is that she is entirely self-supporting for special ops missions, the largest being smaller than platoon sized groups.
All of her air wing will be specifically reserved for supporting her spec ops ground forces. The air wing and it's pilots will all be Marines, specially trained in extreme close air support. She will not embark any fighters, as the Navy and USAF had the air to air thing covered pretty tight.
Whe will have some PBR's on board, with several on the flight deck pre-rigged for slinging under helos to drop in for an additional extract option and/or riverine fire support.
the ship will have minimal armament, but extra super secret squirrel coms gear, so lots of antennaes and warts around the island and deck.
Airwing will consist of the following:
Hueys and sea knights for infil/extract
a ch-53 (just cause I have an extra sitting around)
possibly some early cobras, but fire support will be well addressed momentarily.
Skyraiders for close ground support (I love the spads!)
A C-47 converted to a Spooky gunship. yes I know this is a stretch, but I really wanted to make one of L'arsenals new C-47's and since I don't do dios, this is the only excuse I could come up with to use one. The gunship will give a longer range or allow it to loiter in the nearby airspace to rain soe serious hate down on the VC in a hurry if the ground troops need it.
Probably a converted Neptune as well for the exact same reason I am using the c-47, I just want one!
And probably a few A-26's (converted from trumpeter B-25's) for additional badassery, and further range than the spads.
My intent on this build is to use up a lot of my spares that are sitting around, and the only purchases for the build are the L'arsenal aircraft and PBR's. everything else I need is stuff that has been sitting around my workshop for years.
Feel free to offer suggestions at will. I ant this to be as practical as possible (after admitting that I am stretching it a little bit with the Spooky and Neptune) and be a ship that very well could have served.
She will be designated CVSO-13 (Carrier, Special Operations), and most likely commissioned as the USS Douglas T Jacobson, http://en.wikipedia.org/wiki/Douglas_T._Jacobson A medal of honor recipient credited with killing over 75 japanese on Iwo Jima
- sgtryan13
Re: 1/350 'Nam Special Ops Carrier
Here are some shots of the before state that my Essex was in. I think we can all agree she was in bad need of some type of help, be that in the form of styrene surgery, or an open flame!
And yes, I ran out of paint when I got around to the starboard side of the ship!
- sgtryan13
And a few shots of some very early hack work I did while waiting on the Bush to dry.
gtbred, I was thinking of you the entire time I was tracing and cutting my flightdeck template!
Cool idea. My impression of the refurbished USS Ponce is that she is the real life counter part of your idea.
- gtbred
no problem Ryan. Coral Sea will have a all plastic angle flightdeck and island. J.F.K is all plastic. looking forward to your build.
- sgtryan13
Well I am slowly getting back into things. I suffered what turned out to be a major case of Nats lead-up burn out. I have tried a few times to work on some projects, and just wind up sitting there staring at directions and references. So to cure the burnout, I have done a little work on the SpecOps CV, which allows me to be as creative as I like and not check references and instructions.
A big part of what makes the USMC who we are is doing more with less, especially budget-wise. Keeping with that mindset, I want this CV to look like she was converted with a minimal budget. The hull additions will intentionally look like they are "bolt-on" additions, so there will be the somewhat unsightly 1/4 round portrusions you see in the pictures.
the areas I debated a lot about were the bow and stern; I wanted to close them up to give the carrier a more modern streamlined appearance, but at the same time wanted to make her more unique setting her clearly apart from the other Essex CV's that were modernized in real life. Ultimately I decided to keep the open bow and stern, which will serve 2 purposes; it will make her look different than the others, and it will be in keeping with the cost saving low-budget yet effective theme.
I added a starboard flightdeck extension, and the island will be moved outboard onto this extension, clearing a little more deck room. The relocation of the island is probably not in line with the cost saving measures, but maybe that is why they decided that they would leave the bow and stern open.
The long hull extension on the port side will accomodate the storage and hoisting/lowering of some of the PBR's. I am still considerig sealing up the fore hangar doors on each side, since the 2 outboard elevator openings will provide more than enough open spaces, but we'll see.
- Nansen
Not really a what-if fan, but this idea was interesting. Seems like you have most areas covered as well. My suggestion would be some early satcom antennas. I did a quick search and came up with an interesting page http://nhatrangsatcom.com/.
Only question I have is it really possible to launch a C-47 from a carrier?
Erik
Erik
- sgtryan13
There will certainly be some satcomm domes aboard, on the island as well as a few dotting around the hull.
As to the C-47, I admit, it is a long stretch, and not very probable, but ijust wanted an excuse to use one, so there it is. Technically speaking though, it would be possible to take off, if my research is correct that in WW 2 a C-47 needed slightly more than 800' to take off. Now if they could get a B-25 to takeoff in way less than that from the hornet, I imagine they could do something to shorten the C-47's distance as well, maybe even use JATO rockets if they had to.
Anywho, the main shape of the island is done, the new fore bridge constructed from scratch and modified parts from the tamiya enterprise kit. the new stack and upper works were cut out of "butterboard" a gift for me to try from Gary Kingzett, and I love this stuff, it is giving me a lot of ideas for future scratch projects, namely an eventual 1/350 build of the USNS Stockham...
- Nansen
And it will be "Puff, the magic dragon"?As to the C-47, I admit, it is a long stretch, and not very probable, but ijust wanted an excuse to use one, so there it is
- sgtryan13
Nansen wrote:And it will be "Puff, the magic dragon"?As to the C-47, I admit, it is a long stretch, and not very probable, but ijust wanted an excuse to use one, so there it is
Of course it will be!
- Nansen
Looks great... What is "ButterBoard" can you explain what it is?
Keep up the great work... Some thoughts for build.. Don't forget the huge refueling Rig that these carriers had on the starboard side.. What are you going to use for the gun's the double 5 inch or open 3 inch/50 call like LPH-2 class had?
- sgtryan13
***disclaimer*** I am by no means an expert on butterboard, hell I am not even knowledgable about the stuff. That being said, this stuff is really cool and I am an instant fan. Gary spoke very highly of this stuff and gave me a good sized scrap chunk to try out.
Butterboard is made from some type of wood paste I think, but the best way to describe it would be that it is sort of like a big chunk of hardened resin. It is very strong, sort of heavy, but cuts easily with a razor saw or any power tool. it's best property though is how it sands; this stuff sands like a dream, start coarse and work your way down to finer grits and you can sand this stuff to a smooth as glass finish. I just drew the sahpe of the stack/upperisland on the butterboard, tossed the chunk in the mitre box, and about 10 minutes later I had the whole thing cut and sanded perfectly square and smooth. It is equally easy to whittle and shape this stuff into any shape you may need.
I don't know where to buy the stuff, though it shouldn't be too hard to find, and i am not sure of it's cost, though Gary told me it is not expensive.
As to the build, the UNREP rig will definately be added. As for the guns, honestly I am leaning towards leaqving them all off completely, though IF I do put some on, I will likely go with the 3/50 open mounts. My reasons for thinking of leaving them off are for weight, and practicality, the space could be better used for communications and electronics. We'll see though.
- Dave from Downunder
Does teh butter board look wood like - it sounds like what we call MDF. It basically wood powder with resin to form sheets comes in 3,6,9 mm thick (also thicker)
Yest it sands smooth on teh edges and teh faces are smooth anyway. Used to mack cheap furniture over here as well as may other uses
Am i correct in descibing what you have over there?
1/350 Slipway:
USS John C Stennis
Stennis CBG 2002:
Operational:
CG73 USS Port Royal
DDG73 USS Decatur
CG57 USS Lake Champlain
FFG33 USS Jarrett
Planned
DD967 USS Elliott
USS Salt Lake City (SSN-716)
USS Jefferson City (SSN-759
USS John C Stennis
Stennis CBG 2002:
Operational:
CG73 USS Port Royal
DDG73 USS Decatur
FFG33 USS Jarrett
Planned
DD967 USS Elliott
- Devin
Butterboard is definitely not MDF. Butterboard is as Ryan said, it's poured resin cast into large sheets. It isn't exactly like the resin that kit manufacturers use -- the stuff that I've worked with, with Gary Kingzett (is that where you got your sample, Ryan?) -- is supposedly more stable for outside uses, such as signs, etc. I used some of it to build boat masters for vacuumforming, and it works, looks, feels, and even smells just like the resin in a ship model. Very nice stuff.
This is a great project, Ryan. I've thought a time or two of taking that "so far off it isn't even funny anymore" Trumpeter USS Hornet kit and making it into a post-war what-if, with 5" mounts on the flight deck like an Essex, angled deck, and populating it with the what-if and experimental aircraft like the A2D-1 prop/jet hybrid, the "Flying Pancake", and early Navy helicopters. Putting an angled deck on that Hornet would almost explain the supertanker hull.
-Devin
-Devin
- kidcurrie42
Here is what i found for Butter-Board http://www.goldenwestmfg.com/html/machi ... astic.html
I would keep 2 of the 5" guns and add 2 twin 3"mounts Port side, Manned by Marines of course
Happy Modeling
John
Happy Modeling
John
Si Vis Pacem, Para Bellum
- sgtryan13
Yup, that seems to be the stuff, like i said, it is a breeze to work with, the smoothnness it sands to is just awesome. And yup Devin, Gary hooked me up with it when I picked up the Bush from his house, great modeler, and great guy that one.
I am still undecided on the gun mounts, but I am almost certain that they will def not be on the flightdeck fore or aft of the island, seeing as I am moving the island outboard onto the extension I installed, I really can't see them moving adn reinstalling the gun mounts too. Still up in the air about the guns, but leaning towards no, I am open to hear arguments in support of having the guns aboard though.
I am very happy to report that my attempt to modify trumpy B-25's into B-26 K's seems to be a success. They are not an exact match (I opted not to modify the fuselage to represent the hump on the 26's where the aft canopy goes) But I think they will look the part enough. I scratched a new tail section, and clipped the main wings and added the booms on the ends. They will get a solid nose full of guns and wings full of weapons pylons. IN short, I think they are gonna look pretty badass!
- Devin
You could put some Terrier missiles on board like America mounted for a short time, or you could go really crazy and put some Talos on there! Lots of real estate for those, though. BPDMS would be very plausible, though.
- sgtryan13
I do like the idea and look of the terriers, and the BPDMS would be a simple install, seeing as I probably have a bunch of spares left over from my nimitz class builds. If I go with anything, I think it will be a missile system vs the guns. I am pretty sure that some of the missile systems are available from either veteran and/ or l'arsenal.
Here are some initial shots of the B-26k's I am making. the base is the trumpeter B-25, whcih I think is similar in size and general shape enough to be a good starting point. I scratchbuilt the tail section, sanded off the turrets, reshaped the nose a little, and clipped the wingtips and added the booms on the ends. the noses will get an array of machineguns installed (solid noses) and the wings will get a bunch of pylons and ordinance. these b-26's won't be perfect replicas, but I think they will look close enough for union work!
- Devin
Nice work. You've definitely got the B-26 look down in the tail area and wings. The only suggestion I'd make is to round out the forward area a bit more. The cockpit area is off a bit, but I can't put my finger on why. There's a drawing on line here, if that helps:
http://freercplans.com/img-a26-1-3v-41.htm
-Devin
-Devin
