I wanted to win "Best Ship" in an IPMS contest. I, uh, succeeded and took home the "Best of Show" at the Lafayette show. I'm honestly stunned on that one. My next goal is to take a "theme" award. We have a contest in January with a "what if" theme which interests me. With that in mind, I'm going to take a stab at resin and build Orange Hobby's Graf Zeppelin, ideally in a nice dazzle or disruptive camouflage.
I'm also planning on scratching some little Fl-282s or an Fa-223. I figure the Zepplin's intended use was recon and commerce raiding, so why not fit her with some choppers? I can imagine them being rather useful in locating, tracking, and potentially attack convoys. I'll need some help making the masters for these (if I do both.)
At any rate, this is my first resin kit. I've absorbed all the advice and tutorials I can, cleaned the resin, and began the build.
I'm playing with the dry fit. All the major sections fit beautifully. This is truly a lovely kit.
Currently, I've cleaned the hull and began filling any casting errors. There aren't many. I've also started fitting a few of the platforms along the side of the hull. Most have gone on easily after some sanding. I got a little overzealous and removed a little bit too much on the aft most platform I've installed, but it'll clean up with some putty.
At least it's straight?
Gaps here are minimal and will easily be solved with dilute putty or Mr Surfacer.
Orange Hobby PE feels VERY stiff, but with delicate lattice structures, I like it. I just hope it isn't brittle like some of the Eduard stuff I've used.
I plan to build the PE supports on to the bottom of the forward and aft flight deck projections. I think that will ease overall construction and painting.
Resin is certainly interesting. The plan is to prime her with Mr. Resin, fit her on a sea base and MAYBE display her refueling a Zerstroyer.
Time will tell if I want to take it that far.
