Vincent, it's really pleasing to read such a compliment from a builder of an excellent Tiger!
We had a heatwave here in Hungary which practically prevented me from modelling with room temperatures reaching unbearable levels.
So progress was again very slow.
I did finish the Sopwith Pup though.
This is one really tiny aircraft!
Length of the fuselage is 9 mm - it looks as if it was 1:1200, not 700.
Admiralty Modelworks did a great job with this diminutive biplane indeed.
Still I couldn't help making some improvements to it.
I drilled the cockpit deeper - it was just a shallow recess. The engine bay was also drilled deep and some imitation of the engine built up from stretched sprue was added along with a cowling from wire sanded to shape.
I didn't use the PE interplane struts because the rigging provided with them was deemed to thick.
The aforementioned struts and all the rigging is from thin stretched sprue - still a bit too thick but this miniscule detailwork approaches the limits of what I can do in 1:700. The plane was spray painted and decals were added from the AM set.
In the pictures the aircraft is attached to a small pin.
On top of a coin:
And a ruler:
The placement in the hangar proved to be a tight fit!
In fact I had to bend the front frame outward to be able to place the aircraft inside.
Strips of cigarette paper were attached to the top to simulate rolled canvas.
I'll add crew members pulling ropes atteched to these later along with the rest of the crew.
I think the addition of the hangar with the aircraft inside provides an additional point of interest and enhances the appeal of the model.
Next I will complete the rigging then add the flags and finally the crew.
