Look what the cat dragged in!
I wasn't suppose to get this kit yet but apparently there was some left. I also recieved my Uss Momsen etches today aswell so now it's
gonna be even harded to try to finish that one haha
I also ordered both WEM PE sets and the 130mm guns aswell, hopefully they arrive next week.
As most of you know this kit is pretty flawed, but I'm not gonna let that bum me down as I do love these russian modern ships.
I've build this kit years ago and I think it was one of the first kits I did with any PE. Now years later it has always haunted me and now it
is the time to give it another go.
I started by sanding all the parting lines which the hull was riddled with. After that was taken care of I did some research on the port holes
and filled few of them up and drilled a couple of new ones to match the real thing.They seem to be a bit higher than in real life but I decided
I'm not gonna start dwelling on stuff too much or else I get frustrated.
I also drilled the holes for the Pontos pedestals and secured the nuts inside the hull with some styrene and epoxy.
As I had drilled all the port holes I wanted to add something behind them so I did these crude compartments to give some feel as there would be something behind them.
Later I'll finish the holes with Kristal Klear some other product to make windows. After they were painted I glued the deck down.
I started the detailing from the bow. All the locator wells were filled and sanded as the bollards and chalks were smaller and looked really bad when placed on them.
The chalks were also moved closer to the edges. There were no wells for the anchor chain so I made something according to my reference photos.
I think that's it for the first day!
