It is currently Thu Aug 28, 2025 8:27 pm
Post new topic Reply to topic  [ 248 posts ]  Go to page 1, 2, 3, 4, 5 ... 13  Next
PostPosted: Tue Oct 28, 2014 7:37 pm
With the Z-17 just about done, it is time to starting turning my attention to Gallery's 1/350 "Fighting I". This will be build strictly out of the box. You can find the in-box review here.
I already skipped step 1 (adding the hangar deck), as I've drilled three holes in the bottom of the hull for the finials I'll be using to mount her to her base. I'll get back to that step once the finials are on.
I skipped ahead to step 2 and started with the sonar done. And, just like a similar piece on the Gallery Iwo Jima, the fit was less than stellar:
File comment: You can see the holes for the finials on the "top" (bottom) of the hull
So, I'll have to break out the Bondo and get to work.
More to come - the beginings of this will be slow, as I want to finish the Z-17 in the next two weeks, and I'm catching up on about four years of neglect around the outside of the house - I've spent the last couple of weekends cleaning up all the flower beds. I've already gone through 40 bags of mulch and ain't done yet...
PostPosted: Tue Oct 28, 2014 9:50 pm
This is a very highly anticipated build!! I will be watching this one for sure. Don't let the flowerpots slow you down :big_grin:
Cheers: Laci
PostPosted: Wed Oct 29, 2014 7:01 am
And, so it begins.......
PostPosted: Wed Oct 29, 2014 7:40 am
Geez, that sonar dome fit is disappointing. I should be starting work on this one in a month or so, I need to have it done in time for nats to deliver to her owner who lives out that way.
PostPosted: Wed Oct 29, 2014 12:49 pm
Ryan it is a relative kit to trumpeter remember. I will be following too. Would love to do one with supplies for Nam.
On the Bench
1/350 Independence
1/350 Dunkerque
1/350 Shimakaze
1/350 Sharnhorst Dragon
1/350 Belfast
PostPosted: Sun Nov 02, 2014 1:20 pm
Still working on smoothing out the sonar dome. My tube of bondo is just about dried up, which made it difficult to work with. Stopped at a WalMart the other day to get a new tube, and they were out of it...which figures.
Tried using some Mr. Dissolved Putty as well, but that's new to me so I need to get the hang of it. After filling, sanding and repeating, there is still a visible line on the hull. So, I'll need to go back and touch it up some more.
While waiting for the putty to dry on the sonar dome, I added the bilge keels. Gallery was nice enough to add lines on the hull marking their location.
However, the locator tabs on the sprue are in a crappy spot, which take a little trimming and sanding to get smooth...
PostPosted: Sun Nov 02, 2014 2:30 pm
Martin, did your kits flight deck have sink marks (?) in the flight deck? Mine has three small depression with one forward of the superstructure and two behind it. Just wondering if anyone else had this issue.
PostPosted: Sun Nov 02, 2014 3:16 pm
Ryan, don't sweat it, i slapped it together less any extras because we have no extras yet, all in about one month, you'll make it happen,
Keith
PostPosted: Sun Nov 02, 2014 8:23 pm
I took the flight deck out of the box to take a look. At first, I didn't see anything, but as I angled the deck, I saw the slighted depression aft of the island and another farther aft, just aft of the deck edge elevator. Looks like they are associated with what must have been a locator tab during the injection molding process. They are very faint, I can see why I missed them at first.
PostPosted: Wed Nov 12, 2014 9:18 pm
While ruminating over the fate of the Z-17, I did some additional work on Intrepid...
File comment: Calling the seam in the sonar dome "done"
File comment: Added the struts and shafts
Found the fit of the struts onto the shafts a bit wonky - almost bent and broke one shaft. It took some sanding of the shafts and boring out of the part the strut slides through with a rat tail file to get them to fit properly. Moral of the story: take your time, sand/test fit, then repeat as needed. Now I need to go back and putty where the struts go into the hull - there are some small gaps here and there.
PostPosted: Sat Nov 22, 2014 7:46 pm
Finally found time to do some more work on CV-11. After puttying and sanding small gaps around the struts and shafts, I found time to airbrush the bottom of the hull. This allowed me to permanently install the finials that the ship will rest on. Which meant I could finally install the hangar deck and start moving ahead on the build...
Hopefully I'll start to make some real progress now!
PostPosted: Mon Nov 24, 2014 9:15 pm
Started adding sponsons and platforms around the sides of the hull and at the stern...
Then I started working on the structure at the aft end of the ship, that supports the flight deck.
So far, no reamajor fit issues (knock, knock on wood).
PostPosted: Thu Nov 27, 2014 6:51 pm
Added the sides of the hangars today. The outside of these parts have lots of nice detail. The inside, not so much. I've decided to cheat and close the hangar almost entirely up, which saves me some painting. Plus, you can't see much anyway.
Once the sides were up, I dry fitted the flight deck in place, just to make sure everything lined up.
Fit of the hangar bulkheads is pretty good. I only had to fill a few spots. So far, she's going to together fairly quickly and easily. (Knock on wood)
I've skipped a step in the instructions. I'm bypassing the aft platforms and flight deck supports for now, and adding all the parts to the sides of the hangar bulkheads. I'm trying to add as many items as possible before having to paint, but the aft platforms will need paint before assembly of all the parts and flight deck supporst, so I'm going to do that section last.
PostPosted: Fri Nov 28, 2014 8:20 am
A contest winner in the making!
It looks like the shape of the hull was captured so much better in this kit than Trumpeter did with its 1/350 Essex/Yorktown/Ticonderoga (a bit blunt and boxy) and its Hornet (a reefer van).
Can't wait to see you do your detailing magic.
Have fun, Monkey around.™
PostPosted: Sun Nov 30, 2014 2:16 pm
You are too kind Steve.
Progress continues. This is really a pretty easy boat to put together. I've got most of the sponsons around the side of the hull on, and have reached a point where I need to paint before I add anything else. Here's the photos...
File comment: Flight deck is only dry-fitted to check alignment and fit
File comment: The three sponsons on the base support the angled flight deck. I'll paint them separately before adding them to the hull.
File comment: Some more photos, this time without the flight deck.
A few comments: Gallery did a good job on where they located the attachment tabs on many of the parts. There is also some really nice detail on the outside of the hangar bulkheads and on many of the sponsons. Really gives the kit a busy look.
Hoping to crank up the airbrush today and start doing some painting. Stay tuned for more...
PostPosted: Sun Nov 30, 2014 5:16 pm
I'm tuned. Love the bulkhead details on the gallery deck. Oh Trumpeter, why didst thou betray me?
PostPosted: Tue Dec 02, 2014 10:13 am
Looking good Martin! I will be following this with great interest as this kit is on my hit list to be converted to the Hancock.
Gabriel
PostPosted: Tue Dec 02, 2014 10:28 am
Thanks guys.
LOL
PostPosted: Tue Dec 02, 2014 9:12 pm
It must be something of a relief to have the pieces go together relatively well for a change. This speaks well of the kit. I can only dream...
PostPosted: Wed Dec 03, 2014 1:19 pm
Yeah, the Trumpeter North Carolina this ain't...
Users browsing this forum: Bing [Bot] and 5 guests
