Well, what seemed a quick, straightforward build turned out to be something completely different...
First of all after I applied the base coat it revealed that this model is actually made of cheese...
those tiny bubbles are quite embarrassing and needed huge amounts of filling and sanding and the portholes were inevitably filled too and had to be re-drilled...
and the next thing: all the parts are cast in a thick layer of resin which is quite hard to remove especially if one wants flat even
surfaces
nevertheless the bulwarks aer quite thin and fragile and I managed to damage some parts during the sanding process so they were repaired using plastic strip
Because this is a generic Hunt class type II kit the searchlight platform/auxiliary control position provided had a different shape than the one in HMS Chiddingfold so some scratchbuilding was needed based on photos and the drawing in the Friedman book
so this is a much more demanding work than I anticipated
greg
