It is currently Fri Apr 19, 2024 7:00 pm
PostPosted: Tue Aug 16, 2016 8:46 am
I stopped working on these for a while, but just now ordered some 1/3000 aircrafts from shapeways.
For 1/3000 the details are quite good (especially the horizontal details) and they are the size that doesn't need spray painting so it's quite fun to build/paint quickly for a change.
All the ships planned for the base..
Musashi - because the AA arrangement is clearly a Leyte version but it's missing some other components such as directors/additional AAs, so I added some where appropriate (with mini rocket launchers :))
Rebuilt the main mast, crane tower, cut out the one piece catapults and replaced with properly shaped ones. Hollowed out the stack and added PE grille...yeah...
The 2 shiratsuyu classes, main issue is replace the moulded on main guns, and reshaped rear AA gun platform/mast
Shokaku - added radar as per 1944 setting, thinned the front flight deck to give space to add the AA platform at forecastle and the flight deck supports. Thinned the rear flight deck to give space to add in boat platform as well as adding the rear AA supports. The decal provided worked pretty well though. And soon I'll be able to add aircrafts to her (as well as possible float planes to the other ships!)
Takao - the kit doesn't come with main mast! Also cut out the torpedo openings, added radars, modified stack etc
Nagato - my least favourite outcome, the superstructure looks a bit chunky/off despite a lot of thinning/shaping. Main mast completely rebuilt as original kit part is one chunk together with the crane boom
Oyodo -
The dock with ships placed..
I'm considering design/etch some face plates for the buildings as well as replacing all the cranes for a proper finish...
PostPosted: Tue Aug 16, 2016 11:00 am
Nice. Are these the Fujimi 1/3000 units?
PostPosted: Tue Aug 16, 2016 1:08 pm
Really nice work :thumbs_up_1:
Greetings Christian
At work:
1/700 Fujimi IJN Shokaku 1941
1/700 Aoshima IJN Hayasui 1944
1/700 Aoshima IJN Yukikaze 1945
1/700 Rainbowmodel Fuyuzuki 1945
PostPosted: Wed Aug 17, 2016 10:44 am
Good inspiration. I have the Nagasaki Sasebo set coming.
Jack
PostPosted: Fri Jun 09, 2017 8:49 am
I finally have something of an update
3D printed aircraft from shapeways
PostPosted: Fri Jun 09, 2017 11:50 am
Lookin' good.
PostPosted: Fri Jun 09, 2017 1:19 pm
Looks really good and I thought I was somewhat loco for my size diorama but geez 1/3000 scale!!!!!!! AWESOME JOB!!!!!!!!!!!!
Jim Varnell
ABH2 USN/RET.
89-00
Eastern NC Modelworks
Up coming projects:
(Table 1 underway)Feb.2017
PostPosted: Mon Dec 02, 2019 8:40 pm
Good looking build!
A good friend of our son just posted to 5th Fleet. His first international travel, and I'm building the modern-port version of this kit in homage. Same base plate as the WWII version, with modern structures that fit over a number of the earlier structures to bring the kit current.
Craziest of all is the decal sheet includes roadway and parking striping for the base. That masking task is next.
Users browsing this forum: No registered users and 122 guests
