It is currently Fri Feb 22, 2019 5:13 pm
Post new topic Reply to topic  [ 104 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
PostPosted: Wed Apr 26, 2017 9:32 am
Hello,
The previous diorama being finished. I started this day drawings for the next.
The scene will be the large 250-ton crane in the port of Hamburg in 1940.
The ship will be the Bismarck - KIT Revell with the Kit details Pontos Models. As I find interesting to post you the advanced Assembly of cranes and building. But for the Bismarck, there is so much editing of this ship on the forums. That I will not post the Assembly of the ship. I'd start posting the ship during the painting of the effects of the weather.
I spent these last 2 months to draw the different elements of the diorama. The result is 19 boards in A4 format.
The diorama going to 850 mm x 345 mm. Below a plan available to the different scenes.
Looking from the front: on the left a set of work and storage with cranes (4 total). 2 per span on the same track. I've simplified the topic because normally when there are two wheelchair bridges they are on way to rolling bunk.
Below, there will be a fabrication with 3 sets mecanosoudes and finishing court yard. I have scaffolding and characters while you work (riveting, welding and painting). Characters are originally from the 1/700 drawings made by Migou31 for its diorama on mare Island.
At the center of the diorama. The Bismarck (during the visit of the Commander Lindemann for its command). And behind the 250-ton crane.
The latter designs were more complicated than expected. The previous Nagasaki crane is composed of 2 subset (one vertical and one horizontal). It breaks down into 5 subsets. The result 6 Board A4 for a total of nearly 400 pieces. The editing will be more sensitive
Behind the crane two building. 1 represented by its façade and the other a warehouse in wood with an open front. As pictured below.
On the right of the diorama, I planned a feature of the port of Hamburg. The dock of unloading of commercial vessels. At that time there were different (10) docks formed on the same principle. For my part I chose the platform representing a building with a dozen cranes for unloading of materials. Below photos (indicated on the picture source) having served for the stage design.
And of course a rail set with cars and loco. For the loco MIGOU31 gave me his BR50 with tenders board. A big thank you to him.
I will complete the diorama with a set of vehicles (cars, trucks, cars, etc.) to the 1/350th at L'arsenal.
Today, I opened the elements of the kit of the Bismarck by including details from PONTOS Kit.
On the latter, they are planning to replace all the vertical walls with detailed elements of PE. The bad surprise being that all doors are closed. And I like to do open doors. Especially for dock building. Then I'll repaint all the walls by with the doors open.
The following receipt of PE boards.
I wish you a good end of the day.
Best Regards
Alain.
PostPosted: Wed Apr 26, 2017 10:27 am
Well, that's a big project.......and sounds great! Can't wait to see your progress :thumbs_up_1:
Brett Matthews
PostPosted: Wed Apr 26, 2017 9:04 pm
I echo the previous poster, yes a robust undertaking, it will be neat to see this progress.
Mark
On the bench:
1/200 Rodney
1/32nd Wingnut Wings Post War NINAK
PostPosted: Wed Apr 26, 2017 11:20 pm
This will once again be an eye-catching project! Can't wait to see the first progress! :woo_hoo: :woo_hoo:
P.S. You will also be making your own set of PE for the Bismarck, right? It would be really great if you could make it available for sale for others as well...
Edit: i just read you will be using Pontos set, so that would be good as well.
Aop
On the way:
And our artworks!
PostPosted: Thu Apr 27, 2017 5:01 am
that will be one heck of a project... good luck with this one...
PostPosted: Thu Apr 27, 2017 6:42 am
will you do her in winter as per the photo posted
I like the ice on the water--and with all the( coal ) smoke around back then ...
you can afford to weather it even more...!! :cool_2:
watching!
Jim Baumann :wave_1:
PostPosted: Sat Jun 10, 2017 11:24 am
Hello everyone,
I finally received my boards of PE (19 boards in A4 format). With a month late or everyone believed the package was lost.
I had already recommended the boards when the parcel arrived. So cancel and explain with Hauler Ltd. They are really super professional professionals.
So these last 5 days, mount the crane. 200 hours of drawings to draw this crane. 420 pieces for a width of 280mm and a height of 215 mm.
When creating the boards I forgot to put a dozen pieces. That's why I can not close the subassemblies.
I present the 1 blank assembly knowing that there are still many details to set up and solve a design problem that I have difficulty understanding (parallelism of the pivot arms of the arrow.
I enjoyed setting up this crane. This is by far the most complicated I have done.
Best Regards
Alain.
PostPosted: Sat Jun 10, 2017 11:35 am
Great work on the PE and design work. You should be proud of the results. I look forward to seeing the next installment.
Scott
Salisbury, NC
USS Iowa BB61 1943 post refit
1:200 Trumpeter w/ Pontos detail up with deck
USS Missouri BB63 1945 1:350
In planning T2-SE-A2 tanker AO-82
PostPosted: Sat Jun 10, 2017 4:07 pm
WOW! That is just SO over the top!!!!
Kevin M
PostPosted: Sat Jun 10, 2017 6:43 pm
Will your crane be commercially available from Hauler?
:wave_1:
PostPosted: Sun Jun 11, 2017 1:27 am
SovereignHobbies
SovereignHobbies
That is brilliant!
James Duff
Sovereign Hobbies Ltd
Current build:
HMS Imperial D09 1/350
PostPosted: Sun Jun 11, 2017 1:33 am
Wow, fantastic!!! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Another ambitious project from you Alain, and with a spectacular start!
Looking forward to the next steps. Personally, I wouldn't mind you posting progress on Bismarck too… :)
Marijn
PostPosted: Sun Jun 11, 2017 8:12 am
To quote Jack Nicholson's Joker, "Where does he get those wonderful toys?"
Amazing and beautiful work.
Have fun, Monkey around.
-Steve Larsen
Catalogs of over 2000 products for scale modelers:
3D-printed gray resin (best material!) - https://www.model-monkey.com/
3D-printed Shapeways' white acrylic - https://modelmonkey.wixsite.com/modelmonkey
PostPosted: Sun Jun 11, 2017 8:32 am
Wow. A beautiful piece of custom work.
PostPosted: Mon Jun 12, 2017 5:46 am
pff, nice work on the crane... You did a nice work drawing this one out in PE, let alone the construction of it... looks very promising...
PostPosted: Mon Jun 12, 2017 10:32 am
Wow, that is impressive work!
PostPosted: Tue Jun 13, 2017 9:33 am
Alain,
Very impressive work so far, I love the diorama plan. Can't wait to see it all start to come together and I will be following with great interest. Best regards.
Jim Varnell
ABH2 USN/RET.
89-00
Eastern NC Modelworks
Up coming projects:
(Table 1 underway)Feb.2017
PostPosted: Fri Jun 16, 2017 10:10 am
Hello everyone.
Thank you for your encouragement and your participation in this post.
After the crane, I tackled the construction site, storage with the cranes. This scene which will be to the left of the diorama is 170 mm by 200 mm, for a height of 80mm.
The layout suits me a lot. On the other hand I have modifications to make on:
- one side (the right support) that supports the overhead traveling cranes. I forgot to mirror her boyfriend across the way. It is one of my great classic that kind of forgetfulness.
- And on the upper supports. These should be extended by 2 mm on each side. And also I have to make them higher, because the top of the rolling bridges does not pass underneath.
- Replace the roof of the building which is too large and especially in a thickness of 0.2. Currently it is engraved in a thickness of 0.3 and the hollows are much too pronounced.
I have planned welded assemblies in progress. As well as scaffolding.
The welders and the painter are drawings of Jean (Migou31) that he had originally made at 1/700. I modified them slightly, to make them in double thicknesses and added folds of clothes in order to ease the painting of these last ones.
In the following pictures, the wooden warehouse and open on one side (see layout diagram of the diorama). It is great and with the dock it goes very well. These dimensions are 105 mm, by 46 mm for a height of 36 mm.
I also made handling items. Wagons of two types and vintage devils.
I also made new box formats and reviewed the drawings of the previous ones. Now they are nickel and mounts very easily.
And in the following picture: the 150 cases I have to mount (LOL).
For the other elements of the diorama, I have to review the drawings, because there are a lot of stuff that do not go.
Good day end to you.
Best regards
Alain.
PostPosted: Fri Jun 16, 2017 12:22 pm
So impressive....this will be great to see come together.
:woo_hoo:
Brett Matthews
PostPosted: Sat Jun 17, 2017 6:10 am
:worship_1: :worship_1: :worship_1: :worship_1: :worship_1: :worship_1:
Amazing! ¡Asombroso!
Users browsing this forum: JCRAY and 11 guests
Search for:
