I had bought a couple of submarines in 1/400 scale but finally decided that I would stick to 1/350 so they will not be built.
Later I learned that the Swedish submarine HMS Delfinen II (The Dolphin 2) were constructed by the same Dutch company as the Soviet S-class subs.
I had a look at the S-13 kit and decided that it was probably useful as a base for a conversion to the Swede.
I removed a couple of mm of the stern and four mm at the center and glued the hull together again.
Delfinen was a mine-layer so I added some plastic card and Magic Sculpt to the hull.
The keel had plastic card added to change its shape.
With the basic shape done I think that it is doable.
Björn B
http://www.baecklund.eu/scalemodels/home.html
