It is currently Tue Dec 18, 2018 3:52 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: 1/350 CV-12 Hornet
PostPosted: Wed Sep 06, 2017 8:01 pm
Here is the beginnings of my 1/350 CV-12 Hornet project. It has started life as an Intrepid kit, a lot of research, looking at photos and a lot of help from Jodie Peeler has put me on hopefully the right track.
File comment: The original kit piece
File comment: The modified piece
 Post subject: Re: 1/350 CV-12 Hornet
PostPosted: Wed Sep 06, 2017 8:09 pm
More images.
I am going to re-skin the whole deck to correct the catapults and cover the joins from moving the elevator and re shaping the aft end of the flight deck.
PostPosted: Tue Sep 12, 2017 8:11 pm
Progress has been slow but here is a small update. I printed a new section to replicate the roller door setup on the starboard forward sponson. I will cut the kit piece and join it to this so it continues along as intended in the kit.
PostPosted: Tue Sep 12, 2017 8:38 pm
That looks to be a pretty ambitious project, mate. Modifying a WWII-era Essex-class kit into a specific ship would be difficult enough, but taking one from the angled-deck era and doing so sounds like a daunting proposition indeed!
Will be keeping a lookout on this one. :wave_1:
On the ways:
1/200 Trumpeter HMS Nelson
In the stash:
1/35 Italiari PT-109
PostPosted: Tue Sep 12, 2017 9:06 pm
It will be a long term project, I know it won't be 100% accurate, but I think it will be close.
PostPosted: Mon Sep 25, 2017 6:44 pm
Some shots of the deck progress. Re-skinned with .010 sheet, every tie down point drilled out by hand. I am yet to cut out the foward elevator.
PostPosted: Tue Sep 26, 2017 9:27 am
Thanks for sharing, this is fun to watch.
http://www.f-16.net
http://www.c-130.net
Building:
1/48 Su-33 (decals being applied)
1/48 RA-5C (painting)
1/350 CVN-65
1/350 Gato (painting)
PostPosted: Sat Sep 30, 2017 5:33 am
That flight deck looks great! :thumbs_up_1:
How did you determine the location of all the tie-down holes?
Marijn
PostPosted: Sat Sep 30, 2017 11:16 pm
Marijn
I am lucky enough to have a brother who is a civil engineer with access to a massive paper printer, he drew the whole deck to scale and then drew a criss cross pattern over the whole deck at 7mm intervals. The intersections were where the tie downs are. I cut the paper pattern out, glued it to some .010 sheet and drilled and scribed the details and cut to the shape of the deck. Once it was done I soaked the whole lot in water until the paper and glue washed away. I have actually removed the front section as I was not happy with it, I have some more sheet on the way to re do it.
PostPosted: Sun Oct 01, 2017 5:36 am
Thanks! That sounds like the perfect way to do this.
The result certainly looks more perfect than measuring and drawing by hand probably would.
PostPosted: Sun Oct 01, 2017 8:01 am
Thanks Marijn, It worked surprisingly well which is great because I have had to strip the whole lot off again. I realised the holes for the deck tie downs were too big for scale. The intrepid deck has them roughly sized at 0.7-0.8 mm which is what I replicated. Scaled out this makes them around 25cm-30cm in real life. The new holes need to be around 0.3mm to be more accurate.
PostPosted: Wed Oct 18, 2017 8:08 pm
I was not pleased with the first deck, the tie downs were out of scale so I took it off and started over. I chose to scribe the catapults and elevators on this time, I think once its in primer it will come together nicely.
PostPosted: Sun Oct 22, 2017 8:13 pm
Some primer on the deck helps bring it together.
PostPosted: Sun Nov 12, 2017 6:27 pm
Progress has been slow on this one but here is a small update. I have 3 out of 4 of the starboard sponsons on, the Hornet ones are very different and smaller compare to the Intrepid. I have added the aft roller doors and recessed that part back as best possible, it won't be 100% accurate but it's close.
*edit* I dont know why the images are upside down, they open the right way when you click on them,
PostPosted: Mon Nov 13, 2017 5:47 pm
R32WA,
MAn that scratch work is looking great the images though made me feel a bit dizzy, just kidding but again your work is looking great and can't wait to see more.
Jim Varnell
ABH2 USN/RET.
89-00
Eastern NC Modelworks
Up coming projects:
(Table 1 underway)Feb.2017
PostPosted: Sun Dec 17, 2017 12:45 am
It has been a while since I have had any bench time but got some recently. Here are the updates sponsons and the crane sponson mounted. The port forward doors have been replaced with the 3 roller doors that the Hornet has. Soon I think I will be at the stage where I can mount the sides permanently and then move on to the island etc.
PostPosted: Sun Dec 17, 2017 1:22 pm
Ambitious and impressive work!
PostPosted: Sun Jan 28, 2018 6:24 pm
Some more bench time this weekend.
PostPosted: Tue Mar 06, 2018 7:05 pm
I finally got around to getting some bench time and managed to get some photo etch work done. I have the Model Monkey Hornet island on order, that should be the final piece I need.
PostPosted: Wed Apr 18, 2018 8:33 pm
Finally some more bench time, so here is some updates.
Users browsing this forum: Koppalakki, wefalck and 11 guests
Search for:
