Hi guys, many thanks for your warm comments. This gives me a lot of motivation to continue with the project.
I will slowly upload more images as the project goes on, but it will be a long process as I only get about 30 minutes modelling time a day. It already took me around 8 months to get to the stage as shown in the pictures.
marijn van gils wrote:
I love it when modellers don't just add a detail-set to their model, but instead use whatever available and then add scratchbuilding to get the best possible results.
I totally agree with you marijn. And this is exactly the philosophy I used on this project. I don't particularly like the idea of simply using a detail-set to solve the problem. This takes out the fun from modelling. It also means putting complete trust in the accuracy and fidelity of the set manufacture's research which I always had non-positive experiences with.
Dan K wrote:
Exquisite work, and I appreciate the devotion to accuracy and detail. I have been contemplating a similar conversion on and off for some time. FWIW, I still think the Pit-Road turrets might be better shaped, but it's close.
Hi Dan, many thanks for your kind words. This project actually started up as a quick conversion job crossbreeding Fujimi with pit-road and ended up now as a full blown scratchbuild work as I found the pit-road angular bridge is a total nightmare to correct. So maybe you can get the motivation to start the conversion by first viewing it as a quick kit bashing work
Personally, I prefer the Fujimi turret as like you said the shapes are very close between the two but I think Fujimi's detail is more crispy than PR
