It is currently Mon Jun 25, 2018 12:31 pm
 Post subject: building 1/350 bismarck
PostPosted: Tue Feb 13, 2018 2:48 am
Using the revell plate, the PE set of the lionroar , some general parts and self designed PE and self-made.First, we should use toothpaste to patch up the soil to make up for the huge gap, then cover the water spray soil to make the armored welding stripe, the armored zone with the area line to make the armored seam, then start to make hull camouflage.
PostPosted: Tue Feb 13, 2018 2:52 am
Add some of the VTM's tonic, such as the loudspeaker, the 20mm artillery, the 37mm artillery, the observation group, the searchlight group, the fire control group, the ammunition box.Then start adding PE details to the superstructure, and color color separation.The observation window top command provides no improvement, can only use the 0.2mm copper bar bent to do the electric drill out of the window ledge, the shape of the
PostPosted: Tue Feb 13, 2018 2:56 am
Then remove the details of the Revell's board, the stack, the chimney and other details, and change it into the PE details.The rear mast is used metal mast which made in china
PostPosted: Tue Feb 13, 2018 1:14 pm
Online
:thumbs_up_1: great work
PostPosted: Thu Feb 15, 2018 9:15 am
looks great. i have a Revell 1:350 Bismarck in my stash, so i could get some ideas here.
PostPosted: Tue Feb 27, 2018 2:10 am
Then continue to transform the rear bridge, and cover the spray paint.The AR196 water reconnaissance board, which is produced by the trumpeter hand, is reformed with the set of LR, and is covered with the shade, and then the tone is deepened by the wash technique.Make the aircraft and the corresponding equipment well and install it in place
PostPosted: Tue Feb 27, 2018 2:13 am
Using PE, metal cannons and resin parts to transform 105mm antiaircraft artillery.Transformation of traffic boats and parts to install parts.Color split levers and bumpers and installation of climbing and rope connections
PostPosted: Tue Feb 27, 2018 2:16 am
The installation of ring tendons on the top of the turret is difficult to rebuild the main turret.Main guns here I used the main guns metal gun fire kits are also produced, with resin gun cover.Then install some scattered parts, make the line and the old, wait for the finished photo.
PostPosted: Tue Feb 27, 2018 3:21 am
Online
:thumbs_up_1: excellent work
PostPosted: Tue Feb 27, 2018 7:45 am
Wow. Nice.
PostPosted: Wed Feb 28, 2018 2:13 am
That's a very good looking Bismarck!
PostPosted: Sat Mar 17, 2018 1:34 pm
Very nice Bismarck I must say!
Users browsing this forum: Google [Bot] and 20 guests
Search for:
