It is currently Sun Jul 20, 2025 7:04 pm
Post new topic Reply to topic  [ 19 posts ]
PostPosted: Wed Nov 07, 2018 5:24 am
Hello everybody!
Last summer I was busy and together with my friend we were build a model of aircraft carrier Admiral Kuznetsov (Trumpeter 1/350) with PE and scratchbuild stern (balconies, propellers, shafts, stern tubes, keel and stern profiles).
It took 4 months.
My IJN Haguro 1/700 waits his airplanes and figures. It's a big hard work.
So, after that I want to build simple model.
And this model is modern Zvezda kit - K-551 Vladimir Monomakh Borei-class SSBN
Last weekends I started to build model.
1. cut through scuppers
2. make boxes behind the scuppers and paint them in black
3. assemble rocket mines, containers, missiles
4. assemble hull
5. start to remove plastic shagreen from surfaces and deck
Image\
For standing model I will use Adlers Nest naval model display stands (set M)
Earlier I want to cut through the grates on the bottom of hull, but I don't find good PE lattice to replace their plastic imitation.
Andrew
Andrew
1/350 battleship Sevastopol 1914
1/700 heavy cruiser IJN Haguro 1942
1/350 SSBN K-551 Vladimir Monomakh
PostPosted: Wed Nov 07, 2018 5:45 am
Looking forward to you build report!
(And looking at your previous pics I assume you still resemble to person on the left in the first pic?)
PostPosted: Wed Nov 07, 2018 6:15 am
Yes, on the right my friend who did most of the work on the model of Admiral Kuznetsov
Andrew
PostPosted: Fri Nov 09, 2018 3:52 am
Pasted screws in the hull for the stand
Made work stand (not for displaying)
Assemle all hull. Next I will scribe engraved panel lines to make them more deeper.
Assemble and modify conning tower
Andrew
PostPosted: Fri Nov 09, 2018 6:33 am
Great start! :thumbs_up_1:
And good idea to throw in a less intense project once in a while! :smallsmile:
PostPosted: Fri Nov 09, 2018 6:46 am
Thank you Marjin!
After Haguro and Kuznetsov - Borei is relax work :big_grin:
I need more power to finish 4 seaplanes and 200 sailors for Haguro
Andrew
PostPosted: Mon Jan 21, 2019 3:09 am
Last two months I did't build this model.
And last week I have some progress:
- rebuild scuppers
- improve propeller
- rebuild front horizontal rudders (add end plates)
- rebuild stern horizontal rudders (Reduced span by 7 mm for each rudder, add rotation axis)
- rebuild stern vertical rudders (add rotation axis, rebuild form)
- install stern rudders to hull
- restored engraved panel lines
Andrew
PostPosted: Tue Jan 22, 2019 1:17 am
Love the work you are doing. For A Sub I am surprised by the Number of Parts in the Kit......Cheers Mark
If I was your Wife I would poison your Tea
If I was your Husband I would drink it
Winston Churchill
PostPosted: Wed Feb 06, 2019 4:11 am
Progress of last 2 weeks:
- deleted plastic bollards
- make new bollards from Evergreen 0.88 mm толщиной
- make new railings at conning tower from copper wire 0.2 mm
- installed conning tower, lights
- make many holes at deck and hull
- make rods of sliding devices, antennas, flagpoles, periscope from syringe needles 0.4, 0.6, 0.7, 0.8, 1.5 mm
- assemble all details
----- Manoeuvring thrusters
----- missiles well covers
----- missiles and their containers
----- small antennas at hull
- buy new Tamiya scriber/engraving blade
The model is ready for painting!
Andrew
PostPosted: Wed Feb 06, 2019 7:21 am
Здорово! :smallsmile:
PostPosted: Thu Feb 14, 2019 3:21 pm
Wow. Very nice work!
Отлично сделано.
PostPosted: Wed Oct 02, 2019 5:13 am
Continue building SSBN
- fitted stand
- primed hull (GSI Surfacer 1200)
- fixed many assemble bugs
- prepare for painting
https://c.radikal.ru/c41/1910/ee/b49051fe0c8f.jpg
Andrew
PostPosted: Wed Oct 02, 2019 6:50 am
Start painting
Andrew
PostPosted: Wed Oct 02, 2019 6:53 am
Yep, just a "simple" follow-up build. :smallsmile:
Looks good.
PostPosted: Sun Oct 06, 2019 5:38 pm
Looks good.
Thank you Dan!
Ready to apply decals
Andrew
PostPosted: Sat Oct 19, 2019 5:29 pm
Apply decals
Next - laquer & weathering
Andrew
PostPosted: Wed Oct 23, 2019 5:38 am
After semi-gloss lacquer Mr. Color and Set/sol for decals
Andrew
PostPosted: Mon Oct 28, 2019 5:12 am
Current view of model
Andrew
PostPosted: Sun Nov 24, 2019 4:27 pm
The model is finished!
Andrew
Users browsing this forum: No registered users and 67 guests
