As Larry so rightly put it
Quote:
Just a note - be careful with the Pontos instructions.They're not always 100% accurate - plus, they're damn hard to follow in places!!
Quite!
The following is a snippet from the Pontos instructions to fabricate the 4" ready lockers -
and even though you can zoom right in, there is no real direction as to what to do.
This is what I did!
The basic box is easy enough, but attaching the doors takes some thinking. Because the, eventual, locking latches are in the way, it appears that there is no easy way to attach the door.
The door hinges have to fit under the latches somehow. If you look at the edges and top of the box you can see the latches sitting proud of the surface, four on each side and two at the top.
Here's my method. Slide the door hinges into the latches on the left side, the door is then held in position at an angle, but the right side ones then interfere, using a pair of square nosed tweezers, simply turn the lower 3 latches on the other side of the box to the outside at about 45-60 degrees. this then allows the door to lie flush to the box.
The hinges can then be pushed down to the edge of the box
and the latches turned inwards to lock the door in position
Once all the latches are holding the door in place
the door hinges can then be pushed down into their rightful place on both sides.
The doors are actually held in place by the latches and are not glued in place at all! It sounds complicated but in reality it probably takes around a minute per box to attach the door.
I hope the above makes sense, and, as usual, any questions or comments are always welcome.
Cheers, Jabb
