It is currently Thu Oct 22, 2020 9:24 am
Post new topic Reply to topic  [ 15 posts ]
PostPosted: Sun Aug 23, 2020 4:21 pm
Hello everyone! With Tennessee pretty much done I started to work on a new project (or projects maybe). I have two of the IHP USS South Dakota BB-49 kits and one "defect" hull. My plan is to build these three as they would have appeared in late 1941 in a new battleship division (Willow Green Turret tops). The kit depicts the ship in an "as-built" configuration. IHP calls these "Craftsman" kits, meaning all of the pieces necessary to complete the ship are not included, but instead need to be supplemented from other sources (They recommend Trumpeter Tennessee and Colorado class kits). Included in the kits are main gun turrets, superstructure, and funnel. The "defect" hull had a large hole in the bow that was easily repaired with some putty.
File comment: Can you tell which one was a defect?
Since I was "modernizing" the kits, and one was just a hull, I decided to start by designing a newer superstructure to better represent a 1941 configuration. I used SketchUp to design the superstructure (not the best program, but I know how to use it) and then printed it on my Anycubic Photon SLA 3D printer. The first iteration of the superstructure ended up being too long as I miss-measured and forgot to measure as I designed. The first print also showed some flaws in my print support structure. I shortened the superstructure about 5mm and changed my print support structure. This time the print looked beautiful and was the right length.
Here are pictures of the first iteration that was too long
Here it is after modifying the 3D files
Test fitting on the ship
And finally a comparison shot between my 1941 version and the kit as-built version
Since I plan on building three ships I'll slightly modify the superstructure for each one. The actual plan at this moment is to build two with cage masts and one with tripod masts. Up next I will probably start designing the funnel and main turrets to 3D print, since one hull was just a hull without the other pieces. I am thinking about possibly going with a different funnel and superstructure arrangement for one of the ships, but we'll see.
-Abram
PostPosted: Sun Aug 23, 2020 7:23 pm
wouldn't go tripod as is some what retro-grade but go New Mexico class style superstructures of the 1930's.
https://www.model-monkey.com/battleships-700
PostPosted: Mon Aug 24, 2020 10:01 am
Looking great! You get some really good looking prints on your Photon, what slicing software are you using?
Yes, However there was a plan that circulated(again, never built so pretty much anything goes) that showed them being completed with a Tripod mast. If we think about when these ships would have been being completed and look at when the other Battleships began their "Tripod conversions", it is possible that these ships or at least some could have been completed with the Tripod.
For the turrets, I have a .stl that I can share with you if you drop me a PM with an email.
In the yards right now:
USS Utah AG-16
On Hold
1/350 USS Portland CA-33 1942
PostPosted: Mon Aug 24, 2020 11:32 am
Nice work! That looks really cool. 3D printers have completely revolutionized the hobby.
PostPosted: Mon Aug 24, 2020 12:05 pm
Matt, most likely they will be finished superstructure wise like the "Big 5". as the "Big 5" did not appear to have major structural changes except blisters before Pearl Harbor as they where too new then same goes the South Dakota's. the 1 area I would change is the combined stack as looks like Japanese style to the 2 stacks of the "Big 5" or the single stack of the Pennsylvania\New Mexico classes.
PostPosted: Wed Aug 26, 2020 9:11 pm
Thanks to Matt for the turret file, saved me a ton of work! I resized it, basing the dimensions loosely on the kit supplied part. I printed 4, but will probably print 8 more for the other two ships. I printed these sans barrels as I'll be using brass barrels instead.
New turrets
118208277_323042135704448_4550177432812175799_o.jpg [ 194.74 KiB | Viewed 802 times ]
Turret comparison
118373653_323042165704445_8085463734692571054_o.jpg [ 138.42 KiB | Viewed 802 times ]
-Abram
PostPosted: Sat Aug 29, 2020 9:45 am
Nice!
Have fun, Monkey around.
-Steve Larsen
Catalog of over 2500 products for scale modelers - https://www.model-monkey.com/
PostPosted: Wed Sep 02, 2020 10:00 am
A new update on my South Dakota (BB-49) builds. Got some base color down on one of the ships. She'll be Ms1/5 in the traditional 5D/5L. I also modified the superstructure for the second ship and got it printed out.
I've also started my attempt at designing the funnel to print (not pictured). I'm going to attempt cutting a wood deck overlay from one of the generic sheets that are offered online.
118657206_327703755238286_6362710019955801486_o.jpg [ 210.91 KiB | Viewed 599 times ]
118672049_327704341904894_3829117876571274403_o.jpg [ 254.33 KiB | Viewed 599 times ]
118399413_327703898571605_8168443106801271476_o.jpg [ 140.69 KiB | Viewed 599 times ]
118684767_327704435238218_8797896208649380237_o.jpg [ 252.77 KiB | Viewed 599 times ]
118599722_327704395238222_2553420679587131237_o.jpg [ 304.37 KiB | Viewed 599 times ]
-Abram
PostPosted: Thu Sep 03, 2020 11:30 pm
Started adding brass barrels to the main guns. I had only bought one set to compare to others I had. I fixed I liked these and ordered more for the rest of the ships.
118654846_329334641741864_8943794155267613868_o.jpg [ 169.34 KiB | Viewed 527 times ]
118582346_329334685075193_2472535725381985236_o.jpg [ 131.17 KiB | Viewed 527 times ]
-Abram
PostPosted: Fri Sep 04, 2020 10:55 am
Nice! They are an improvement over the kit turrets.
PostPosted: Fri Sep 04, 2020 8:18 pm
Thanks! Another update; as mentioned before I am painting the first ship in Ms1/5 so today I painted the false bow wave. After which I tried weathering the hull a little.
118804623_330961778245817_2865073676430101675_o.jpg [ 213.08 KiB | Viewed 454 times ]
118857429_330962258245769_3469736385429669137_o.jpg [ 241.65 KiB | Viewed 454 times ]
118669955_330962594912402_5637134180596231396_o.jpg [ 235.44 KiB | Viewed 454 times ]
118799018_330962654912396_8256545398620927808_o.jpg [ 128.27 KiB | Viewed 454 times ]
Got a lot of small parts primed today too.
118768468_331269441548384_5588980047155052164_o.jpg [ 130.03 KiB | Viewed 454 times ]
-Abram
PostPosted: Fri Sep 11, 2020 2:57 pm
Painted a second hull this week. I thought it'd be fun to post a b/w photo of it with the other ship and my Tennessee. What color is it?
118777730_332736598068335_1484033195687656313_o.jpg [ 267.69 KiB | Viewed 373 times ]
I also Got three of the turrets finished. I needed life rafts and like the ones included in the Trumpeter Big Five kits. I made a mold of a bunch of the rafts and cast my own. Once painted you can't tell the difference. Following the "what if" theme I went with green turret tops for a new battleship division.
118893331_334444591230869_2513604960311220211_o.jpg [ 266.99 KiB | Viewed 373 times ]
118930769_334445261230802_1123887381169399799_o.jpg [ 192.54 KiB | Viewed 373 times ]
119002403_334445421230786_1102348795086844413_o.jpg [ 173.58 KiB | Viewed 373 times ]
I'm kind of at a stalling point on the first ship at the moment as I wait for some parts in the mail
-Abram
PostPosted: Fri Sep 18, 2020 2:21 pm
Some inspiration for you, Abe....from Mike Bartel of IHP, on FB:
PostPosted: Fri Sep 18, 2020 3:37 pm
if those ships were not at Pearl Harbor attack then would have at most have similar modernization as Maryland had near end of war which is more then what Colorado got.
PostPosted: Mon Sep 21, 2020 11:37 am
Looking good! :thumbs_up_1:
Keep the updates coming!
USS Utah AG-16
On Hold
Users browsing this forum: marijn van gils, pascalemod, Willie and 43 guests
