The Karakurt class of ship's (also known as Project 22800) is the (for now) latest class of stealth corvettes for the Russian navy. They are meant to be more seaworthy then the Buyan-M-class which were designed for the littoral zone. With the hostillities in Ukraine, ssome larger projects were halted/pauzed and this is a cheap alternative for the Admiral Grigorovich class frigates...
These ships are armed with 8 vertical launchers for Oniks/Calibr anti-ship cruise missiles, a 100mm A-190 dual purpose gun, 2 AK-630 CIWS (first two ships), Pantsir M CIWS or Palash/Palma CIWS.
First hulls were laid down in 2015 and were commisioned in december 2018 and october 2019. 14 More ships are being constructed or launched allready.
The kit:
and the parts:
early hull:
Late hull:
Various parts:
PE, decals and barrels:
Detailing seems to be nice and crisp, but looking at the Combrig version of this ship, I would recommend the latter, a lot more detail is added, but I suppose that it will also add to the difficulty of building it...
Not my first ship I'm busy construction, but the railings were always a bit of a halting point, So on with that bullet, an appointment with the dentist has been made just in case...
Progress:
For the railings I worked with some kind of PVA-glue (gators grip) later on to be reinforced with thin CA
The small cages are for the liferafts... found it more easy to solder these into place then to glue these... less fuzz
Also found out that applying a bit of solder to the bends makes them stronger, at least less vulnerable to break. I'm aloso trying to thicken the PE-parts that need some body:
Same with these reinforcements to the sides, the supports are separate parts (luckily they provide too much off these) and I've found it more easy to solder these then to glue... just a matter of habbit I suppose...
