Finished wih the cold water fear now. After several attempts at gluing that Vivak plate (clear polyester, clearly not the same as acrylic), I was confident enough to go for the final gluing. Remade a couple of panels in the meantime, since the MEK is not evaporating like acrylic weld glues.
The vessel itself is now far enough to continue with the subsea equipment and lay-out.
So currently I've glued the two lengths and one side together in a U-shape and then glued that to the "sea surface" plate.
The one open side allows me to measure and work underneath for lining up the sub-sea equipment with the vessel on the surface.
I started by making the "quadrant", which is used to lower the final part of the cable while the end is being pulled inside the monopile foundation.
Currently shaped the cable from 0.3mm copper wire (will paint it later on), which is draped around the quadrant. I've made the loop in the middle so I could shift left and right to line up with the vessel. In order to allow this shifting, I've raised the clear casing on top of 4mm of styrene pieces (1 on each corner to keep decent lining up). This way I can shift the wire to its final position before cutting off the excess.
The plan is to glue it on the base, along with the quadrant and the wire on which the quadrant hangs. the most difficult part will then be lining up the standing wire with the hole in the sea surface (if that makes any sense
The second subsea part, the ROV, will be done first since it will be placed further from the open panel. Still figuring out how I will make the tether system.
