DavidP wrote:
what is with the white plastic panels mounted on the left side of the 5" gun mounts & what thickness are they? do you know what mark the turret mounts are as the vertical face below the gun barrels seems to tall for a mark 38?
http://archive.hnsa.org/doc/guncat/cat-0460.htmhttp://www.navsource.org/archives/05/pix1/0577033.jpgyour mark 37 director seems to be riding high from the deck.
http://www.navsource.org/archives/05/pix1/0577022.jpghttp://www.navsource.org/archives/05/770.htmThe panels on the left side of the 5'' gun mounts your refer are clearly visible on Uss Lowry and some other ship of the same class but i simply ignore the purpose of this feature or the real thicknes of the plate, some photos have these pop up clearly and in others are barely visible (see photo below). At firts, in my build I opted for a 0.25mm thick plastic sheet but i planned a later replacement to 0.13 mm thick plate, perhaps more "in scale".
The vertical plate under the gun barrels was simply too high caused by the wrong shape of the original resin piece. I noticed the same thing while adding the four plastic strip under the guns but at this stage i have too chose by reshape all the turrets or live with that mistake in place. I choose the latter, being aware that even the hull is 4mm too short I decided to adding as mach detail as possible working on that scale but not to dramatically change the shape of any major component of this model, so I had to live with that.
I didn't notice the director sitting to high but reducing the ring on the pilot house's roof can be rather simply to do.
Thank you David for your interest and your very keen eye. Cheers!
Alessandro
