Hello ladies and germs, I am working on my Tamiya 1/350 USS Enterprise and I am doing it by video. I will keep posting up links as I add videos. I plan on also converting this kit into RC, and for those interested in that aspect that material is provided as well.
I would like the ship to be a three to four function system, which means I will need to merge two controllers of different frequencies into one. Up to this point I always built my ships with two functions, but for the aircraft carrier I would like to insert an additional function to control more features, mainly I would like a mechanical arm to push a switch which can toggle 50% power or 100% power to the motors.
I am presenting the USS Enterprise as she was in 1986, and I have bought two or three additional aircraft sets (which some I won't need) in order to replace the F/A-18 Hornets that came with the kit. As much as I would love to be able to control every little thing, such as rotating sparrow launchers, I don't have the time or money to go that far. I will build her in 1986 fashion, and with my best effort I would like a rotating radar dish above the island as well as a lamp that will light the superstructure (can be toggled on or off). I am debating on whether to cut into the island side to allow room for a switch- maybe not. Instead of the receiving antannae coming out of the island (it's more trouble than it's worth in that cramped island) I will have the antannae come out between the crane and island. Because the Enterprise is so large, I am considering adding an additional battery supply in parallel along with the second system. Who knows, I may be too lazy to implement more functions- because honestly I don't have qualms about taking the ship into dock and lifting up the decks to change a couple of things.
The ship will be Ipod compatible and I have been playing the role of sound engineer by putting together play packages using the program Audacity. Everything is working great so far! Once I learned how to work the program, it became a lot of fun.
My goals for the Enterprise:+ Hour playtime (Electrical Engineers- if you know the mAh of a 6volt Nicad I would greatly appreciate it
+ 1986 representation
___________________________________________________
VideoPart 1- Systems Talk and Motor Modifications (
http://www.youtube.com/watch?v=3K_rVoit-6Q)
Part 2- Hull Preparation and Painting(
http://www.youtube.com/watch?v=3JIhjkbw058)
Part 3- Final Systems Checks(
http://www.youtube.com/watch?v=w6xhVFlCmVk)
Additional VideoSolidworks- Grease Box Solution(
http://www.youtube.com/watch?v=DkYANfa_koI)
Solidworks- Speaker System Solution(
http://www.youtube.com/watch?v=9q7pDlWcoMI)
Soundtrack Test 1(
http://www.youtube.com/watch?v=12Bp2yV05Bg).
Motor Problems(
http://www.youtube.com/watch?v=vJ3gPhbiRzw).
