It is currently Wed Feb 26, 2020 2:10 pm
Post new topic Reply to topic  [ 131 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Sat Jan 10, 2009 2:51 pm
Arnaud,
that deck looks excellent. Just about as realistic as it gets, I'd say. :thumbs_up_1:
Image Heiko S. | MY SHIPYARD | Under construction: JDS Takanami (Takanami Class Destroyer)
PostPosted: Fri Jan 30, 2009 2:07 pm
Arnaud
Hows she going ? , looking good so far, don't tackle much 700 scale myself, but fancy a go sometime.
PostPosted: Sat Jan 31, 2009 1:41 pm
I have been a bit busy lately with the kids but I started working on the airwing. I'm doing the Tomcats at the moment. The Trumpeter planes are far from perfect, they need a lot of putty to fill in some defects. Maybe I have not been lucky with my sets...
I'll post something soon :cool_1:
Arnaud
On the workbench:
1/72 F-14A Bounty Hunters First Tomcat deployment
1/700 CVN-71 Theodore Roosevelt Last Tomcat deployment
1/700 CG-62
PostPosted: Sat Jan 31, 2009 2:00 pm
Arnaud i have noticed your absence. I m happy you find time to post again. Yes the Trumpy aircraft are far from perfect. I ll be waiting for your post with pics of your 1/700 aircraft.
On the workbench:
Various 1/700 aircraft.
Juan Carlos I LHD 1/700.
HMAS Canbera LHD 1/700.
FGS Type 122 class FFG 1/700.
LSD-41 class LPD 1/700.
PostPosted: Sun Feb 01, 2009 9:51 am
Working on the Tomcats. There is a big gap under the belly on both reactors. This comes from a very poor design from Trumpeter, I can not understand why they did not do like PitRoad, where the landing gears come into small holes: Here the gear is part of an element of the reactor. It's a bit complicated to explain but:
1) The design of the model sucks
2) The fit is terrrible, over 1mm gap between the parts
The parts just assembled, the gear themselves are cut out as I will use GMM PE parts for these. The left arrow shows the excessive thickness of the part, the right arrow the misfit.
After putty and sanding:
Now, paint an additional layer of black under the cockpit (I intend to mask these with masking fluid), add the tails and start the actual painting :smallsmile:
Arnaud
On the workbench:
1/700 CG-62
PostPosted: Sun Feb 01, 2009 10:15 am
Yep, i know what you mean with the Tomcats, I got 2 boxes of Fujimi ones to replace them.
PostPosted: Mon Mar 30, 2009 10:32 am
Arnaud,
That is some of the most impressive deck painting I have seen. It just looks fantastic. One thing about you that really impresses me is the fact that when you have found that you have made a mistake, you are so willing to go back and make it right. I find myself doing the exact opposite, I just get to a point where I have to move on. Keep up the good work!!
My personal modeling site: http://keldq.webs.com/
PostPosted: Mon Mar 30, 2009 10:47 am
Thanks Kelly, coming from you that's quite a compliment :woo_hoo:
I've been stuck on this project for the past two months due to a PhD, a family and a lot of rowing going on but I started working on it again yesterday. I will complete the deck (Just the JBDs to finish now, I messed a bit with the original parts so I had to do them again from scratch) and start the painting of the airwing. I'm planning on having some of them with open canopies, thanks for your nice tutorial on the subject. 1/700 canopies may be a bit tricky but I did a test with an F/A-18 and it should work. Hopefully.
Arnaud
On the workbench:
1/700 CG-62
PostPosted: Mon Mar 30, 2009 11:22 am
Welcome back Arnaud. Hope to see some pics soon. :wave_1: :wave_1: :wave_1:
On the workbench:
PostPosted: Thu Apr 09, 2009 2:19 am
Here is a tiny update, I finally finished the deck. I still have the catwalks to do but the main paint job is done. Finally. :roll_eyes:
I think I've been a bit too heavy on the "dirty deck" effects but it's close to some pictures. My next CVN (Yes, there will be a next CVN, Nektarios got me infected :smallsmile: ) will be cleaner. But just a bit as I really don't like it when it looks brand new :cool_2:
Now I'll work seriously on the airwing, I decided to do like Sauragnmon and have a deadline, otherwise this model will never be completed. I will keep the deadline to myself though, just in case :big_grin:
Arnaud
On the workbench:
1/700 CG-62
PostPosted: Thu Apr 09, 2009 8:02 am
Looks great to me arnobiz. I too don't like a clean carrierdeck. :thumbs_up_1:
PostPosted: Thu Apr 09, 2009 9:14 am
I m happy to infect you. Good job on the flight deck :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :wave_1:
On the workbench:
PostPosted: Thu Apr 09, 2009 2:27 pm
Great work Arnaud, deck looks superb :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Happy Modeling
John
Si Vis Pacem, Para Bellum
PostPosted: Fri Apr 10, 2009 3:32 am
Super nice Arnaud! What are the chances of you building me one of those decks when I get around to building a CVN? :big_grin: Seriously though, great work!
PostPosted: Sun Apr 12, 2009 5:28 am
Anytime Orb but even if I charged £2/hour of work it might turn out to be quite expensive :P
I started working on the stern, there are a few mistakes in the kit and I did not follow the intructions. They recommend to assemble all of the stren components and then stick it on the hull but I feel it would make the joints difficult to hide. Instead I glued the face on the hull first, it will be easier to putty and sand the joint. I'll add the inside components of the stern later. I know I'm a complete maniac about seams, I just hate it when one can see that the finished model was assembled out of smaller bits.
I also worked on the planes, they are almost ready to be painted. Here is a comparison between Trumpeter (top) and Skywave (bottom). As the Skywave planes are molded in one bit they look much flatter and I really prefer the Trumpeter's. I have never seen any Fujimi F-14 though, they might be even better.
Arnaud
On the workbench:
1/700 CG-62
PostPosted: Sun Apr 12, 2009 10:07 am
Fantastic work on the CVN. I assume you ll make some of the aircraft with open canopies???
On the workbench:
PostPosted: Sun Apr 12, 2009 10:11 am
Yes, I will give it a try at least :smallsmile:
As you saw I already drilled the cockpit holes in the Skywave F-14, as they have an opaque canopy I had to open their canopies if I wanted to include them. The point is that I have "only" 14 Trumpeter tomcats so if I want to have most of the airwing I must use the two Skywave I have. On the other hand as these are larger than the Trumpys they will be put in the backgound of the hangar.
Arnaud
On the workbench:
1/700 CG-62
PostPosted: Sun Apr 12, 2009 10:28 am
Truly outstanding, I have been admiring this post while building my CVN 71. I cannot imagine the difficultly doing open canopies. I cannot paint them straight let alone cut them off and clean them up.
Thanks for posting,
John
http://s935.photobucket.com/albums/ad195/jgoodac36/
PostPosted: Mon Apr 13, 2009 1:52 am
I thought it might :big_grin: Therefore, I'll just sit back and continue to watch your build from here and hope that my deck will look half as good as yours someday. Great job so far!
PostPosted: Mon Apr 13, 2009 3:52 pm
Lol Orb I looked at your website and your models are really good, I can't wait to see your Nimitz diorama!
I worked a bit more on the tomcats. On the picture I posted yesterday the Trumpeter plane is painted with a brush. Bad idea: the hair marks are as big as the plane :doh_1:
Therefore I removed all the paint with oven cleaner and started again with my airbrush. I bought this Aztec airbrush 10 years ago, definitely worth the investment!
1) Mount all the planes on a toothpick with white glue (easy to remove but reasonnably strong).
2)Apply the liquid mask on the canopies. Don't do it before you mount the planes on the toothpicks as you might accidentally remove the mask, it's quite fragile. I put mask on all planes (Except the Skywaves of course) even though half of them will have open canopies. The reason is that there will probably be a few accidents with the mask and that way I will just have to remove the canopy on the "missed" planes to get rid of the problem :cool_2:
3)Spray a few black coats on the planes as a primer and to give a dark background to the clear canopies. Comparing this picture with the one of yesterday one can clearly see the difference in quality between brush and airbrush:
Arnaud
On the workbench:
1/700 CG-62
Users browsing this forum: Google [Bot], gtbred, tomcat Fanatic and 13 guests
