Thank you for the kind comments SG1 and Jim!
Actually you Jim pointed out to me about the butt-ends, and now I cannot ignore the effect it has.
A small update regarding the 8,8cm gun mounts on the deck. The guns by the forward funnel are clearly 8,8cm FLAK L/45 mounts, there are pictures of them. Near the rear funnel, the mounts look a little different. According to the Kagero book, these were 8,8cm SK L/45 as evident on the picture below. The shield is different because these were the guns in the casemates under the armored bridge.
There is a nice diagram in the Staff book (page 17)
The problem is that i could not find a more detailed gun in this scale commercially, so I have to make one. The kit parts are very simple and I need 4 that look the same, so I go back to my 3D printer.
I am ashamed to post this design here from Tinkercad because of all the really professional people here posting proper 3D design, but this is what I can do until I learn how to use the proper software and techniques. Also noted is that the actual part has to be "printable" and I more or less already know the limitations of my printer. A really detailed 1:1 3D model will not print with what I have. At least the dimensions are somewhat OK.
The printed result with the brass barrel applied.
