OK, I know I'm the only one posting things here, but my ideas aren't really that bad are they? Now, those shipments I was talking about in the last post have been canceled (No Niko LST available fromo Pacificfront), so instead of spending $40 on 4 loose cannon landing craft, I've decided to take a first leap - and order from e-bay. I am getting a skywave diorama set or two (Not telling my sources to get everyone I can. Muahahaha!), but I will say that if I got all of the Skywave Amphibious sets I found, it would be well over $100. I plan on getting, if possible, 2 LSTs, 2 LSMs, 2 LCIs (both types), British LCTs, and two sprues of the Beachhead set. I still might get the Loose Cannon LCTs though.
Anyway, I have also built all of the craft in the Tugger set. The two longer speedboats are now makeshift patrol boats, with twin MGs from the MTB set, and a depth-charge ready to roll off the back. The two shorter ones are now the fireboats I mentioned in my third post, only now, they are pulling 1 and 2 waterline whaleboats that came in the set, and they have a fire nozzle pointing of the port or starboard bows. The cables pulling the boats and firehoses are paintbrush bristles. The crane ship is also mentioned in the third post. I have replaced the boom with one from Verlinden. The small tug from the set is now a makeshift floatplane carrier, with the boom from the original craneship in between the two funnels facing aft. To go with this, I have made a F4F-3S "Wildcatfish" - a spare from a scrapped Hornet. Floats and supports were made using torpedoes from the MTB set and spare PE. (It was my first researched build). I hope to also add a Kingfisher under tow by the ship. The water carrier and torpedo freighter have been modified as What-if Yard Minesweepers (After just a few months, and with Japanese still in the area, I don't think dedicated ships like that would have been shipped there right away), both with scratched masts, rigging, msc. details, and armament. Torpedo Freighter: Hedgehog Launcher, 4 inch gun (fore), 3 inch gun (aft) Water Carrier: 4 inch gun (aft), depth-charge racks The medium tug has been little changed, wit the exception of a 20mm AA gun on the bow. The Large tug has had the deck gun from the IJN No. 13 Subchaser on the bow. The 3 large landing craft in the set have had PE 20mm guns put on the rear(what's that called again), and oine has had a 6x6 ambulance placed on it, heading for the PT boat mentioned in the third post. . The most changed was the Fuel Oil Carrier. Ths has had one of the Gato deck guns added in the center, with a 20mm on the bow and rear. Also added were the life raft assemblies from the Rudderow set. All the other vessels included have been little changed, with the exception of armament and other small details.
Using the subchasers from the Tamiya Gato set, I have made two variations: 1) a normaly built No. 13 2) the other being modified with US armament (ie, a 3 and 4 inch gun, and a twin bofors on the fantail. For the same reason for the "Minesweepers", I doubt any dedicated subchasers would be available, them being needed on the West Coast, in the Atlantic, and at other Amphib. ops. The regular No. 13 is of no use, and has a lot of holes in it, because it is now being used as a target for dummy boms and torpedoes. The range is located on the far side of the mountain. I have taken some modellers licese in being that all of the equipment is still on the boat, except the mast, which is slipping off the side from a previous hit.
The What-if beached Japanese freighter mentioned some time ago was made using the full hull from the Trumpeter Liberty ship, cutting and placing 5 cm of the bow with 7cm of whatever the back is called. I have cut off the rudder assembly and propeller assembly located there. I made a deck out of balsa wood, a crane from a scrapped 1/1200 Enterprise from Revell, a spare bridge from the Rudderrow, a mast assembly from the Gato, and spare gun mounts from the Dragon Laffey and San Diego. It has 2 MGs in the bow, and a spare 88mm from the MTB set. I painted areas of the keel a faint silver, showing paint chips from its time on the rocky shore.The central section has the hold, with supplies all gone, but with boulders thrown down there to prevent the ship from getting loose in the harbor.
In the scrapyard, I have placed 3 Zeroes, found in the freighter, damaged from previous attacks. Also in there, are some Japanese tanks, and a bunch of old, rotting aircraft. Most of the scrapyard is on the rocky shore, next to the freighter, with boulders lining the edge for the same reason there are some in the freighter.
Also, with one more upgrade for the GMC trucks, I have fasioned a fuel trailer seen on the GHQ site, using PE from a DML 1/144 tank, wheels from a 1/700 Liberator, and a wheel from a failed attempt at upgrading a 6x6 truck (which broke in half).
Like I said, I hope I won't be the only one posting, and I'm working on a diagram of the layout, but I just need to know how to post a Powerpoint document here.
_________________ Current builds: Hobby Boss 1/700 Type VIIC U-Boat for my AH
Planned builds: 3 more 1/700 AH submarines
