It is currently Sat Jun 14, 2025 12:50 am
Post new topic Reply to topic  [ 19 posts ]
PostPosted: Thu Mar 04, 2010 12:36 pm
Hello .
My new project 1/700éme, the kit Yumematu the Dupuy de Lome and a parallel scratch the Dupuy de Lome.
Mon nouveau projet au 1/700éme , le kit Yumematu du Dupuy de Lome et un scratch du Dupuy de lome .
Yumematu kit .
Le kit Yumematu .
Molding correct, many pieces.
Moulage correct , de nombreuses pièces .
The funnel is poorly positioned.
La cheminée arrière est mal positionnée .
the opening of the medium is absent
Le puits du milieu est absent .
behind the castle is false
La partie arrière du rouf est faux .
My scratch.
Mon scratch .
a+
patrice
PostPosted: Thu Mar 04, 2010 2:27 pm
Rhâââ lovely !
Superbe sujet et très joli début pour le scratch, vivement la suite!
PostPosted: Thu Mar 04, 2010 3:33 pm
C'est bien stupefiante. Rien ne vous arrete, n'est pas? (j'espere que cette phrase a du sens?) :thumbs_up_1:
Edit by Jim Baumann:
.....in English it means... :smallsmile:
That's amazing. Nothing stops you, is not it? (I hope that this sentence make sense?) :thumbs_up_1:
PostPosted: Thu Mar 04, 2010 5:46 pm
Yes, this sentence is understandable. Thank you.
Oui cette phrase est compréhensible . Merci .
Laying putty, sanding to prepare for tomorrow .
Pose du mastic , pour préparer le ponçage de demain .
Preparation of turrets.
Préparation des tourelles .
a+
patrice
PostPosted: Fri Mar 05, 2010 8:42 am
The hull of the ship after first sanding.
La coque après un premier ponçage .
a+
patrice
PostPosted: Fri Mar 05, 2010 1:50 pm
Which plans do you use? I found the article series (6 parts) in Navires guerre & commerce N°56-61 (Marines éditions). There are a lot of photos included and also many drawings, but not all of them. E.g. a side view (profil, vue latéral) is missing, there is only a longitudinal cut (section longitudinale). I had also problems to find out which armament Dupuy de Lôme had in 1895 (or any other fit). My interpretation is this:
2 x 19,4 cm L/40 Model 1887
6 x 16.4 cm L/45 Model 1893
6 x 6,5 cm
8 x 4,7 cm Hotchkiss
8 x 3,7 cm Hotchkiss revolver guns
4 x 45 cm torpedo tubes
I am looking forward to see more of your model! :thumbs_up_1: I have also bought the Yumematu kit...
PostPosted: Fri Mar 05, 2010 4:31 pm
6 x 6,5 cm
I am looKing forward to see more of your model! :thumbs_up_1: I have also bought the Yumematu kit...
post by PM
a+
patrice
PostPosted: Fri Mar 05, 2010 5:27 pm
What did you use for the hull siding? Is it filler sanded flush with the ribs?
Babel Fish translates:
Qu'avez-vous employé pour la voie de garage de coque ? Est-ce remplisseur poncé à affleurement des nervures ?
PostPosted: Sat Mar 06, 2010 4:28 am
Hello .
Excuse me for my bad english , I'm french .
Milliput .
It is a product that I use for all .
For the sea .
For sloping walls. (I'm not on my English for the word wall )
For the Wheels.
a+
patrice
PostPosted: Sat Mar 06, 2010 12:43 pm
Genial! Vivement la suite
Jack Ray
PostPosted: Sat Mar 06, 2010 2:19 pm
Excellent choice of ship!
I am interested in why you are biding the kit alongside your scratchbuild?
Will you be showing the two models in the different times--pre- and after re-fit/build?
I am watching this with interest!
Jim Baumann
Excellent choix du navire!
Je suis intéressé à savoir pourquoi vous êtes Biding la trousse à côté de votre scratch?
Voulez-vous b montrant les deux modèles dans les différentes époques - avant et après re-fit/build?
Je regarde cela avec intérêt!
Jim Baumann
PostPosted: Sat Mar 06, 2010 6:40 pm
Good morning .
Bonjour .
Thank you Jack for the compliment .
Merci Jack pour le compliment .
Yes Jim .
Yes, the version of the cruiser with three fireplace ( I can not find the correct translation of chimney ? fireplace ? )
Oui la version à trois cheminées ( je ne trouve pas la bonne traduction de cheminée )
Draft military mats and "chimney or fireplace"
Ébauche des mats militaires et des cheminées
a+
patrice
PostPosted: Tue Mar 09, 2010 6:18 am
Hello to all.
Bonjour à tous .
Sory for my bad english , I'm french .
Canoes kit were very average quality ...
Les embarcations du kit étaient de qualité moyennes ...
I'll rework this way.
Je vais les retravailler de cette façon .
So the placement of a keel and a rudder on a small boat, they are between 9 mm and 1 cm.
Donc , la pose d'une quille et d'un gouvernail , sur une petite embarcation , elles font entre 9 mm et 1cm .
If one of you has another solution, I do not mind any information ...
Si un de vous a une autre solution , je suis preneur de tout conseil ...
Canoe kit.
Embarcation du kit .
I sharpened the edges, dug inside.
J'ai affiné les rebords , creusé l'intérieur .
I have briefly sketched the outline of the boat by placing a sheet of paper.
J'ai dessiné sommairement le contour de l'embarcation en la posant sur le coté sur une feuille .
I cut the boat in the middle (this is the most delicate point).
J'ai coupé l'embarcation par son milieu ( c'est le point le plus délicat ) .
I then glued a half on the small profile.
J'ai ensuite collé une moitié sur le petit profil .
I cut the upper part of the paper, remembering to leave the small end of the stem, and cut the rudder.
J'ai découpé la partie supérieure du papier , sans oublier de laisser le petit bout de l'étrave qui dépasse du petit "gaillard avant" , et découpé le gouvernail .
I glued in the starboard symmetry.
J'ai collé la partie tribord en symétrie .
I cut once again the outlines.
J'ai découpé une nouvelle fois les contours .
I sanded the part of the sheet of paper that remains in the inner hull.
J'ai poncé la partie de la feuille qui reste à l'intérieure de la coque .
And I sanded the keel to my taste. Do not forget that little (it is a small 9mm), so I deliberately forced the size of the keel and rudder for it to remain visible after painting.
Et enfin j'ai poncé la quille à mon gout . Il ne faut pas oublier que c'est tout petit (celui là un petit 9mm) , j'ai donc volontairement un peu forcé la taille de la quille et du gouvernail pour que cela reste visible après la peinture .
a+
patrice
a+
patrice
PostPosted: Mon Mar 22, 2010 5:22 am
Impressive technique! :thumbs_up_1:
Luis Crespo "Sparrow".
PostPosted: Mon Mar 22, 2010 6:23 am
Thank you .
a+
patrice
PostPosted: Tue Mar 23, 2010 9:41 am
Hello .
Bonjour .
Excuse me for my bad English .
Excusez moi pour mon mauvais anglais .
Version Dupuy de Lome vith three chimneys
la version du Dupuy de Lome avec les trois cheminées.
Moving from the stern turrets.
Déplacement des tourelles de la poupe .
Transformation of the aft deckhouse .
Transformation de la partie arrière du rouf .
Enlargement of the base of turrets, the base of the turrets of the kit are too small.
Élargissement des encorbellements et des bases des tourelles , ceux du kits sont un peu trop petits .
The deck was not made of wood.
Le pont du bateau n'était pas en bois .
a+
patrice
PostPosted: Tue Mar 23, 2010 2:02 pm
:thumbs_up_1: :thumbs_up_1:
Tres Bien-- Bon travaille
Very Good-- Good work!
:thumbs_up_1:
JIM Baumann :wave_1:
PostPosted: Mon Nov 01, 2010 2:46 pm
Hi Mabmanu,
I have just bought the Modelik 1/200 kit of the late (3 funnel) Dupuy de Lome. I will copy it down to 1/700 and start working on it shortly . It does have the boat deck as you have indicated but it also has planked decks everywhere.
Do you have good sources about the deck planking or deck plating? I have not found any top views yet.
[quote="mabmanu"]Hello .
PostPosted: Tue Nov 02, 2010 8:33 am
Pieter wrote:
Hi Mabmanu,
mabmanu wrote:
Hello .
:wave_1:
pm
a+
patrice
Users browsing this forum: Bing [Bot] and 19 guests
