It is currently Tue Aug 12, 2025 11:23 am
Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sun Jul 10, 2011 10:44 am
Hello!
I want to show as I do models in 1/700. The model becomes from firm Kombrig set «British Harbor Set, 1890-1918».
I don't know English language and I use the electronic translator.
On model has removed all fine details, has corrected the form of superstructures, has corrected case contours in a forage.
It is better to worm his way in the tail of the professionals than to soar above the kettles.
http://www.modelshipgallery.com/gallery/users/Alexey-Nikitin/user-index.html
Last edited by Alexey Nikitin on Sun Oct 23, 2011 10:22 am, edited 3 times in total.
PostPosted: Sun Jul 10, 2011 10:59 am
Has made new fine details on the case, a deck and superstructures.
PostPosted: Wed Oct 26, 2011 10:42 am
Hello!
After completion of the diorama, returned to work on this model.
Made a new chimney, new vestibule gangway, found the fan.
PostPosted: Wed Oct 26, 2011 8:07 pm
Super work there Alexey! :thumbs_up_1: :thumbs_up_1:
Bob Pink. :wave_1:
PostPosted: Thu Oct 27, 2011 7:01 am
YES...! :thumbs_up_1:
very very nicely done.
I like small merchant ships!
look forward to seeing more
JIM B
http://www.modelwarships.com/reviews/sh ... index.html
http://modelwarships.com/reviews/ships/ ... index.html
PostPosted: Sun Nov 06, 2011 1:04 pm
Hello!
Thank you Bob, thank you Jim!
Jim!
I always follow with interest your work!
Painted model. Did the waterline and round windows. It remains to cover all the matte varnish.
PostPosted: Tue Nov 29, 2011 12:46 pm
Hello Alexey, yes that is again a great model.
Olaf
Здравствуйте Алексей, да, что это опять большие модели. :thumbs_up_1:
Олаф
Please excuse my bad English! Thank you.
USS Wad Sworth (FFG 9)
Minesweepers of Dokkum Class
H.M.S. York (Type 42)
PostPosted: Tue Nov 29, 2011 1:33 pm
Hello Olaf!
Yes, large model..., length 52mm :big_grin:
PostPosted: Tue Nov 29, 2011 1:51 pm
Beautiful :thumbs_up_1: How did you paint the (very) thin white water line???
PostPosted: Tue Nov 29, 2011 2:53 pm
Looks like white sprue to me....? good idea...!
You can get a similar effect using 2 layers of decal - red/ white
as used on my Vlad Mon ( I used TL decals)
PostPosted: Wed Nov 30, 2011 9:59 am
Hello!
Waterline is made of painted white fishing line.
Jim, tell us more about your way.
You use this decal? What is the size of the strips you're using?
Thank you!
PostPosted: Thu Dec 01, 2011 1:31 pm
где же "ЕВРО" ее?
Hello Alexey,
where does the "EURO" her?
PostPosted: Thu Dec 01, 2011 2:17 pm
Hello Alexey! :wave_1:
I apply first the thinnest white stripe from decal sheet, keeping it wet and using my eye to keep it dead straight.
Once it has dried I apply a thin coat of ENAMEL varnish- to prevent any danger of the water getting through Acrylic varnish when the the red decal strip is applied- but also so as to prevent the white decal moving with the new wet decal being applied.
Once the varnish has set a the red decal stripe is applied over the top of the white- and again it is lined up using eyes only to give an even white line all along.
I have been doing this for years and it works in 1/350 as well
but in 1/700 it would be very hard indeed to get it sharp any other way
your method works well also--but from certain angles the thickness of the line is visible...?
1/700 examples using red and green decal
( I seem to be getting the lines thinner and better!! )
1) this year http://www.modelwarships.com/reviews/sh ... index.html
2) 3 years ago http://www.modelwarships.com/reviews/sh ... eview.html
3) 6 years ago http://www.modelwarships.com/reviews/sh ... ildup.html
Здравствуйте Алексей! : wave_1:
Я применяю первый тонкий белой полосой от пропуск листа, сохраняя его мокрым и с помощью моих глаз, чтобы держать его мертвым прямо.
Как только она высохнет я нанесите тонкий слой эмали лаком, чтобы предотвратить опасность попадания воды через акриловый лак, когда красная полоса пропуска применяется, но также, чтобы предотвратить белую деколь, движущихся с новой мокрой деколь применяется .
Как только лак поставил красный пропуск полоса наносится поверх белого и опять же выстроились использованием только глаза, чтобы дать даже белая линия все это время.
Я делал это в течение многих лет, и он работает в 1 / 350, а
но в 1 / 700 было бы очень трудно, действительно, чтобы получить его резкое любым другим способом
Ваш метод хорошо работает также - но под определенным углом толщину линии видна ...?
1 / 700 примеров использования красного и зеленого деколь
(Я, кажется, получения линий тоньше и лучше!)
1) в этом году http://www.modelwarships.com/reviews/sh ... index.html
2) 3 года назад http://www.modelwarships.com/reviews/sh ... eview.html
3) 6 лет назад http://www.modelwarships.com/reviews/sh ... ildup.html
PostPosted: Fri Dec 02, 2011 11:52 am
Thank you Jim!
Yes, at certain angles the thickness of fishing line can be seen ......
uaw233 wrote:
Hello Alexey
Olaf hallo!
Können wir ihre sprache sprechen? :wink:
PostPosted: Sun Dec 04, 2011 1:09 am
Hello!
A small extension .....
Homemade anchor:
PostPosted: Mon Dec 05, 2011 1:40 pm
Hello Alexey,
which (write) are talking now in German?
We'd better let us understand english otherwise not the other.
Those are super small anchor. Your skill is amazing for me. :woo_hoo:
Not only that you are the super models to build, and the many details are really great.
Just great. :thumbs_up_1:
Olaf
PostPosted: Fri Jan 06, 2012 12:00 pm
Hello!
Congratulations to all a Merry Christmas and Happy New Year!
PostPosted: Fri Jan 06, 2012 12:25 pm
hello alexey
very nice tugboat , and very original,what size is of your tug?
regards
nicolas
PostPosted: Fri Jan 06, 2012 12:52 pm
Thank you :smallsmile:
Length of the model - 50 millimeters.
PostPosted: Fri Jan 06, 2012 1:12 pm
:doh_1: :big_eyes:
Nicolas
Users browsing this forum: No registered users and 124 guests
