It is currently Tue May 06, 2025 8:56 am
 Post subject: Royal Navy on DVD?
PostPosted: Fri Nov 14, 2008 5:21 am
Hello there!
I`m looking for good quality DVD`s containing WW2 footage of British Royal Navy. Mediterranean sea and Pacific Ocean 1941-1943?
I`m trying to find images of HMS Valiant from that period...
Thank You,
Mikko Saarela
Mikko Saarela
 Post subject: Re: Royal Navy on DVD?
PostPosted: Fri Nov 14, 2008 12:23 pm
The best WW2 RN footage can be found on a series of 12 VHS tapes called the Naval Video Time Capsules. These have since been released on 7 DVDs.
The contents of 11 of the 12 VHS tapes are listed here:
http://home.swipnet.se/~w-11578/photos.htm
Of these, HMS Valiant is mentioned in 3 VHS tapes:
PART 3: CLOSE UP FOR ACTION STATIONS
PART 5: TRAGEDY AND TRIUMPH
PART 10: BRITISH PACIFIC/EAST INDIES FLEETS - Phase one
These 3 parts were released on the following DVDs:
http://www.simplyhe.co.uk/Shop/Maritime ... 124095.htm (which contains parts 2 and 3)
http://www.simplyhe.co.uk/Shop/Maritime ... 124096.htm (which contains part 5)
http://www.simplyhe.co.uk/Shop/Maritime ... 123774.htm (which contains parts 10, 11 and 12)
PostPosted: Mon Nov 17, 2008 9:43 am
Before buying any DVDs, be sure they are proper code for your part of the world and that the TV standard is the same as the one used in your country. In America for example if I buy a British DVD, the code is different so my DVD would not play it, and the TV standard is also different so the TV will not accept it even if the code was correct.
I use an all region all code DVD player with PAL NTSC converter. This allows me here in the USA to play any DVD from anywhere in the world, no problem. A NTSC/PAL converter would be needed by others in the world to play a USA DVD.
These DVD players are not expensive and can be purchased on the internet.
I have alot of DVDs from the UK, Australia, New Zealand, Sweden etc. They play perfectly :cool_2:
Oh! Thanks for the tip on the RN DVDs, I will order then today :wave_1: :thumbs_up_1:
Bob B.
PostPosted: Thu Nov 20, 2008 1:57 am
Thank You both!
Region 2 it is then.
Mikko Saarela :big_grin:
Mikko Saarela
Users browsing this forum: Bing [Bot] and 6 guests
