It is currently Tue Aug 12, 2025 9:18 pm
Post new topic Reply to topic  [ 188 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 10  Next
PostPosted: Sun Jan 25, 2015 12:20 am
Joe,
Love your work. I have a Mono Chrome Akizuki that would pop with new strips. I planned to attach them pre-painting then scrape off the paint once I was done. Thoughts?
- Chris
1/700 Murdertorpedoboat Ooi
PostPosted: Sun Jan 25, 2015 7:16 am
Joe Simon wrote:
I hit the deck with testors dullcoat after I'm dome gluing things down.
Thanks..
I'll keep following.. :smallsmile:
...in my shipyard...
PostPosted: Sun Jan 25, 2015 7:20 am
Very nice.
Scott
K494 HMCS Arnprior
Royal Canadian Navy
PostPosted: Sun Jan 25, 2015 8:33 am
Thank you all for your kind comments. Chris, I would paint the deck first and then put in the brass strips
PostPosted: Sun Jan 25, 2015 10:46 am
That's a good tip. I'll keep that in mind.
PostPosted: Wed Feb 04, 2015 6:33 pm
Are the brass strips part of the Hasegawa PE set? Does the future mess up acrylics if I tried to do the same spthing? Looks great so far.
Gabriel
PostPosted: Wed Feb 04, 2015 8:03 pm
Thank you. The brass strips are from Flyhawk set FH350009. The future will not mess up your acrylic, just make sure it is cured well before applying the future. Hope this helps.
PostPosted: Sun Feb 15, 2015 2:26 pm
Latest progress. Deck work is slow but steady:
PostPosted: Sun Feb 15, 2015 3:19 pm
HI joe
a challenge sacred ,for glued all straight right these strips !!take your time and keep the way
cheers
Nicolas
PostPosted: Sun Feb 15, 2015 4:44 pm
Brilliant work, as usual, Joe!
PostPosted: Sun Mar 15, 2015 1:11 pm
Finally finished with the deck brass strips:
PostPosted: Mon Mar 16, 2015 9:32 am
Your patience to work with those tie-down strip is impressive. Remind me, whose strips are you using?
PostPosted: Mon Mar 16, 2015 10:46 am
That's incredible, Joe. Just thin CA? I'll reiterate what Dan said: the patience is impressive.
- Chris
PostPosted: Mon Mar 16, 2015 6:51 pm
Thank you gentlemen. The strips are from Flyhawk.
PostPosted: Mon Mar 16, 2015 9:58 pm
Oh sorry, yes thin CA.
PostPosted: Sat Mar 21, 2015 2:49 pm
Linoleum perfectly fixed :smallsmile:
PostPosted: Sun Mar 22, 2015 11:58 am
Once again thank you! Main superstructure work. I messed up some of the molded-on tread plate detail. The problem arises while trying to fill seems around the plastic parts. So I simply sanded it all off, cut out some aluminum foil patches and pressed them onto some existing tread plate I had. I like the result. Tread plate restored and no seems.
PostPosted: Sun Jul 19, 2015 5:29 pm
It has been awhile since I've posted. I diverted to a smaller project, the 1/350 I-27 from AFV Club. I wanted to have it for Columbus. Back to Yahagi now. Here are some shots of the I-27:
PostPosted: Mon Jul 20, 2015 8:30 pm
Good to see you back in action joe! :thumbs_up_1: :thumbs_up_1:
Jose :wave_1:
PostPosted: Mon Jul 20, 2015 9:10 pm
Nice. Was it a fun build?
