It is currently Mon Jun 09, 2025 8:32 am
Post new topic Reply to topic  [ 11 posts ]
PostPosted: Wed Dec 04, 2013 3:58 pm
Hi all,
I´ve always liked the type 23 frigates, and finally I got a kit to build one. A friend of mine took a lot of pictures of Montrose at Plymouth in 2011, Trumpeter released a kit, and so I chose Montrose as my subject. The kit goes together very well, but isn´t free of the typical Trumpeter glitches. Even though the boxart shows the proper Kryten turret, you get the original HMS Kent kit with the old style turret and old style 30 mm guns, and Montrose decals only. Well, my friend happened to have a spare Kryten, and I packed the 30 mm guns into "tarps", plus I got the fine WEM PE set, so off I went and just built it. The base was built as usual with me, from a fine grain insulation foam board cut and shaped and filled and sanded and coated with wall paint, spraypainted and sealed with varnish. The Lynx received not the PE rotor blades, as they were thin but virtually without structure, but rather the nerverwrackingly flimsy clear styrene parts sanded down to within a few stray microns of their lives. Figures are the excellent NorthStar resin items, rigging thread is UNI 8/0 and caenis flyfishing thread. Paints are Vallejo.
Best regards
Frank
VMF'06 - German Gamblers
PostPosted: Wed Dec 04, 2013 11:53 pm
Looks great!
Thank god the PE vs plastic issue is not so common place in 700 scale, but still had to do the hub in 3D when putting on PE props!
PostPosted: Thu Dec 05, 2013 5:29 pm
Agreed T23 is a great looking little ship.
Your model looks really convincing. A clean build with just the right degree of weathering = very convincing.
I hope to do mine justice like yours when I find the time for it!
Simon.
PostPosted: Fri Dec 06, 2013 5:45 am
A superb build of a beautiful ship!!! Well done!! :thumbs_up_1: :thumbs_up_1:
NIKOS (NICK)
ΜΕΓΑ ΤΟ ΤΗΣ ΘΑΛΑΣΣΗΣ ΚΡΑΤΟΣ
PostPosted: Fri Dec 06, 2013 12:41 pm
Beautiful model!
The water is very realistic and makes the ship stand out!
Well done! :smallsmile:
Stein
Ultima ratio regum
PostPosted: Sat Dec 07, 2013 1:32 am
Thank you all very much for your appreciative comments!
I really like the look of this class of ship, to me they are among the best looking contemporary warships - so it´s great to have one on my shelf now.
Best regards
Frank
PostPosted: Sat Dec 07, 2013 10:05 am
hello Franck
beautiful work on the ship ,sea, and crew, for a gorgeous result, the all is really convincing
regards
Nicolas
PostPosted: Mon Dec 09, 2013 11:20 am
That is a very nice looking ship. Thank you.
PostPosted: Sat Dec 28, 2013 8:59 pm
Immaculate job. Seen your model before at the Airfix Tribute Forum. Most impressive. :thumbs_up_1:
"We're going to need a bigger boat"
PostPosted: Fri Jan 03, 2014 4:53 am
Thank you all very much for your kind words!
I received the machined brass barrel yesterday and have just installed it; now the model can be fixed on its base - and I can start a fresh project ;-)
All the best from
Frank
PostPosted: Fri Jan 03, 2014 11:46 am
Everything about this build is beautiful.
- Chris
1/700 Murdertorpedoboat Ooi
