back again at the bench at last-- Christmas abroad, New Year and family et al notwithstanding!
thank you Alexey--that helps!
meanwhile...
the seemingly endless boat skids and their vertical supports are now pretty much completed...
at last it was time to start adding some railings-- pleasurable
..(?!_)
I used the WEM ultrafine--and they are....
not as easy or as quick as I anticipated--requiring lots of snipping and cut-and-shut to get stanchions in corners and feasible locations
small platforms in the corners for Q/F guns were added of PE scraps
and in-filled with white glue to make level
The fwd bridge wings were made of brass strip--and had the cut outs for the fwd vents cut in with a drill bit, and the extension circular walkways (to clear the vents)
added with brass circles
the under-deck bracing for the bridge wings
was adapted from some lattice work PE ( Combrig Henri IV ) and had the not-required-gaps filled with white glue
( since the pics were taken its had a second layer and is now level)
Thereafter the very delicate and thin railings were made -- again by joining many small parts so as to get stanchions symmetrical and on the apex of the corners.
the large blister like hawse-pipe openings were enhanced with a raised ring and drilled out.
later on the anchor chain will exit from here and the hawse-pipe lids left partially open
lots of time-- not much tangible progress but
overall its looking quite attractive
the bridge areas will next get chart table, stowage lockers etc etc to assist in breaking up the lino area...
adding the various davist and boats will give more vertical accented interest to the model as well!!
I am hoping to mount the ship to her waterline base next week--that will make it less vulnerable to potential damage threats when handling !
more soon
Jim Baumann
http://www.modelshipgallery.com/gallery ... index.htmlIPMS UK SIG (special interest group)
www.finewaterline.com
