It is currently Wed Nov 25, 2020 3:04 pm
Post new topic Reply to topic  [ 77 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Marceau - Heller
PostPosted: Wed May 16, 2018 6:11 am
finished the railings of back castle finished bow railings...and added some of the railing left overs to make radar look better
For info and might help inspire other...radar was made ;
1. heller railings limed to half their thicknes...cutting sides so spaces between bars get bigger ( 2 large and 2 high).
2. PE railing bars
I will paint PE off course in black...but unpainted...easier to see
I keep all left overs or cut off pieces for...well scratch build
PostPosted: Wed May 16, 2018 1:47 pm
little by little ... it is starting to take form
PostPosted: Fri May 18, 2018 10:33 am
some more small modifications...rear mast lengted by 50% and 2 beams on it...
btw...you can see well on this picture I added a little complication on the 150mm guns
looks I'll have to streighten out some railings...photo's are a real pain..what you hardly see with a loope...you see easely with photo zoom....lol
PostPosted: Mon May 21, 2018 5:54 am
I'm searching whole web to find a gun plan display of the 50' modification...not what guns....I have...but where on the schip...if anybody has...would appreciate.
all the pictures I found of her ... you don't see minor AA guns like the 37/57 or the 20/65....
PostPosted: Mon May 21, 2018 10:26 am
From 1948–1950, Marceau underwent a major refit, in which the forward 10.5 cm gun was replaced by a 15.0 cm gun, the ship's anti-aircraft outfit changed to eight Bofors 40 mm guns and US radar was fitted.
https://www.revolvy.com/main/index.php? ... troyer+Z31
PostPosted: Tue May 22, 2018 9:41 am
Online
Have you seen the photos here? http://www.alabordache.fr/marine/espace ... /photo.php
PostPosted: Wed May 23, 2018 3:11 am
Timmy C wrote:
yes I have...I think I've seen and copied all pics just not a deck layout after modification
I'm waiting for the single 40mm AA guns from arsenal and also their railings to finish her....and ....well...i'll just place the secondary AA guns as best as logic goes
She will be pretty much as good as I can to her French modified state.
haven't seen many ...haven't seen any on the web having done the modification of the bridge ..or even the 40mm guns so...
I'm happy to have done so...kind of unique...
as it is also my first real go at a higher standart of modelling..(major modifications, PE railings).I learned a lot of it witch is to me the best part
I have many ships to come lol
If I would do her again...I'd even lime of the front AA gun boards and put PE railings...they are too heavy...but I suppose...the more you do and have done...the more you wanna improove...there is a moment you must say...it will do.
but hey...she's not finished yet...a new challenge to come...the aireal lines....
PostPosted: Wed May 23, 2018 9:19 am
Triumph68, it all depends on whether Marceau actually had the 20mm guns installed or not. if installed then most likely mounted on the aft structure between the 150mm gun mounts 2 & 3.
PostPosted: Wed May 23, 2018 10:48 am
thought good I'd show how she looks like now, next to her is a german U-boot type IX C/40 I'm doing at same time
for info...all is not yet fixed on thats why middle castle ...say not well placed lol
and looking at her like this....I'm probaly gonna cut a piece from radarfeet so its closer to the base...its too high up
PostPosted: Wed May 23, 2018 11:59 am
I wouldn't do any more work around the platforms that the singles 40mm guns are to be located til you get those guns to make certain those guns with their shields would fit correctly on the platforms.
PostPosted: Wed May 23, 2018 12:56 pm
am waiting my guns before I do any more on her...thats why I used what I learned...pe to finish the sub lol
PostPosted: Thu May 24, 2018 6:08 am
these are the secondairy AA guns...being part of her armament after the French Modification
PostPosted: Sat May 26, 2018 6:51 am
ok...Houston we have a problem
these are the 40 mm guns as received
PostPosted: Sat May 26, 2018 6:57 am
the same guns ..roughly put together...and posed on ship
PostPosted: Sat May 26, 2018 6:59 am
so now there are 2 options...or lime away gun protection of heller kit....or modify arcenal gun platform in order to fit in
...probably gonna be first option
PostPosted: Sat May 26, 2018 9:09 am
looking at this picture...it seems they only had the front screen protection ...not full base as given in arsenal kit...I'll give it a night of sleep lol
PostPosted: Sat May 26, 2018 9:28 am
take the gun tub walls out too as yours is to thick so as to give more room as they are not there in your last attachment. the l'arsenal gun shield is the wrong version & shape for use with a single 40mm gun.
PostPosted: Sun May 27, 2018 6:51 am
so...I decided I'd make modification on the arsenal guns...actualy..on the metal part...reducing the gun base
David...you'd take the full side pannels of and narow a tiny bid the front?(and bottom ...of course)
ok...will do it over some more...got nothing to loose...well...that is..not much..1 arsenal gun lol
PostPosted: Sun May 27, 2018 9:21 am
the gun shield has no sides as the shield face is swept back in the middle like a somewhat flattened "V". look at your 2nd last picture that shows the 4 single gun mounts in front of the bridge.
PostPosted: Mon May 28, 2018 6:02 am
ok...did my thing...rather happy with it
Users browsing this forum: No registered users and 23 guests
