It is currently Mon Oct 26, 2020 5:20 am
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: 1/350 U-Boot Typ VII C
PostPosted: Thu Mar 14, 2019 11:54 am
Hi everyone,
About a year ago I got inspired to build an U-Boot after seeing photos of fellow Belgian modeler Werner De Keersmaecker. I plunged into the deep (pun intended) and got me a HobbyBoss 1/350 U-Boot Typ VII C. Initially I wanted to keep things out of the box, but in the end I decided to replace the plastic guns and periscopes by Aber parts.
A couple of months later I painted the hull and conning tower in their respective colors. Decals were added as well. The kit only gives you options for two ships. I decided to use the black devil insignia, which seems to be inspired by U-552 Rote Teufel.
And so the U-Boot was becoming a shelf queen.
Untill a couple of weeks ago the new Das Boot series got aired, and it made me take the kit again and continue where I left.
First I started out with a pinwash.
After that a filter was applied. Several oil colors were added to a slightly wet surface.
This was then blended in using a clean brush slightly moistened with thinner.
The result is rather subtle, yet difficult to capture on camera
The same process was repeated, but with enamels this time: Humbrol Flesh and Radome tan, to simulate salt spots and streaks.
The pinwash was a bit obscured by the filtering stage. This made me try out a new technique. It's used succesfully by Marijn Van Gils. I painted the shadows with a mixture of Humbrol Flat Black and Raw Umber oil paint
Next I blended the edges a bit.
It's indeed a lot more time consuming than just adding a pinwash (it took me about 5-6 hours in total, 2 for the conning tower alone) but I think it looks better.
Mind though, the photo of the conning tower is blown up so the result look very stark on photo.
I hope to continue very soon ^^
Thanks for watching
Wouter
PostPosted: Thu Mar 14, 2019 3:16 pm
Exquisite.
Very nice work.
PostPosted: Sat Mar 16, 2019 12:32 am
Very nice. Great weathering!
PostPosted: Sun Mar 31, 2019 1:35 pm
Thanks a lot for the comments guys :smallsmile:
Well, weathering has come to a conclusion: I added some dirt and rust streaks. And after that the conning tower and gun were glued in place.
Figures from North Star Models are en route, so looking forward to that.
Next are the two most scary steps for me since I never tried them: rigging and the seascape.
Fingers crossed :big_grin:
PostPosted: Sun Mar 31, 2019 2:09 pm
Very nice! :woo_hoo:
PostPosted: Wed Apr 03, 2019 7:46 am
Beautiful job, never realized the quality of hobby boss kits...
PostPosted: Wed Apr 03, 2019 7:53 am
Online
Great job Wouter, she looks beautiful! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Werner's work is very inspiring, isn't it... :smallsmile:
Rigging and seascape are fun, you'll be fine! :cool_1:
PostPosted: Wed Apr 03, 2019 9:09 am
Good job. One thing - check the boot topping / antifouling black paint levels. You painted along the seams, but it should be painted as a uniform level line.
See pics of them online, or even mine in 1/350 from afv club on this forum, to get an idea. Easy to fix though.
It's never too late for a great childhood!
PostPosted: Wed Apr 03, 2019 10:38 am
Well, that 'underwater' paint line struck me also as somewhat unusual. Nice job on the 'weathering', but I was wondering why the rust-streaks etc. go straight below the water-line - normally the corrosion and fouling develops in more or less horizontal bands. As the U-Boots were welded, you wouldn't see too much corrossion along the plate lines, unlike in rivetted ships, where you would have exposed plate edges.
wefalck
Chairman Arbeitskreis historischer Schiffbau e.V. (German Association for Shipbuilding History)
Image Image Image Image
PostPosted: Wed Apr 03, 2019 1:06 pm
Joe, thanks mate
Jacek, indeed, I was pleasantly surprised by the quality of the kit indeed.
Marijn, thanks for the encouragement. And yes it is. When I visited modelling shows many years ago I never realised I actually saw his work in the flesh. Such great stuff.
Pascale thanks. And now that you mention it, It never occured to me it was wrong, even though I checked out a lot of photos and color schemes. I stupidly enough blindly followed the HB color schemes and box art. Strange because it actually makes no sense indeed.
wefalck, I wouldn't worry about that rust on the lower half, I just dragged the weathering downwards because it was easy. No need to remove it since this one will be placed in seascape ^^
Last edited by GewoonWouter on Thu Apr 04, 2019 11:16 am, edited 2 times in total.
PostPosted: Wed Apr 03, 2019 7:56 pm
Beautiful job!
Michael
Love building and CAD modeling WWII Capital Ships
1/1200 Battle of Hampton Roads diorama in progress
1/1200 1945 USS Pennsylvania CAD model in progress
PostPosted: Fri Jul 10, 2020 6:04 am
Thanks mate :smallsmile:
It's been a while since I worked on this one. House move and all sure didn't help. But I'm properly installed now in the new hobby room, so time to continue this one.
First time seascaping...quite exciting. I watched a lot of youtube videos, read books and tuturials and I'm not trying to do my own thing.
A piece of insulation foam was cut and shaped, and after that I glued watercolor paper soaked in water to the surace. This received two coats of Humbroll Gloss to harden the surface.
After that painting began. I used Vallejo paints in well thin coats. Different greens, blue greens, greys and a bit of black
It looked a bit dull, but when I brushed on a coat of gloss it came alive
Next I tried to give some more texture to the waves using AK Interactive Water Gel. I'm not sure what to think of this product...I think quite a lot of airbubbles appear when you apply this, quite annoying. I have seen videos (Chris Flodberg on youtube for instance) and I have the impression that this happens much less with other gel mediums.
This was followed with the application of cotton using the water gel to simulate the wakes/bow splash. It's not perfect perhaps but for a first time I'm quite happy.
I have no photos of the next step but I pretty much followed Won-Hui Lee's tips by adding thinned AK Interactive Snow and Snow Sprinkles here and there on top of the wakes. After that I'm now in the process of adjusting things using oils paints, mainly using Abteilung Faded White and Blue Green here and there. Since they are oils it's quit forgiving.
And that's where I am at the moment ^^
PostPosted: Fri Jul 10, 2020 6:53 am
That looks convincing :thumbs_up_1:
PostPosted: Fri Jul 10, 2020 7:16 am
Indeed, it does :thumbs_up_1:
I am using artists' acrylic gel medium, e.g. the Lascaux brand, and never had any problems with bubbles, but I build up volume from thin layers.
wefalck
PostPosted: Sun Jul 12, 2020 6:38 am
EJ, thanks mate ^^
Wefalck, thanks. And I think I'll try an artists' acrylic gel medium next time to compare.
So, the rigging has been done. It was the first time I did this kind of thing and iI was a bit reluctant to start with it.
I used Uschi van der Rosten's Rig That Thing Superfine Size wire which is...ridicilously thin. With the naked eye it is barely visible but that's how it's need to be at this scale I think.
Having that said, that also makes it very difficult to apply: it's not easy to keep attached between your tweezers, and even with my Tamiya goggles it was hard to see the wire during application.
But shaky hands, some perseverence, CA glue and a lot of swearing later it has been done.
I must say I'm well impressed with the Uschi wire...it glues very easily and it can be stretched very hard...amazing stuff.
The rigging isn't 100% to my satisfaction, but it isn't bad either.
The insulation balls on the wire were a different thing. Initially I wanted to brush small blobs of paint on the wire but that didn't work out, it's like the wire is the +side of a magnet and the paint a + too...doesn't adhere well. So, next try: small blobs of Micro Kristal Clear. That did the trick. When dry it becomes translucent, so I painted it using Humbroll 32 matt dark grey.
The hull received another application of Vallejo Still Water to make it wetter (another application might be needed) and this is how she looks so far. Finish line is coming close!
PostPosted: Mon Jul 13, 2020 2:40 am
Online
That looks excellent Wouter! Great job on the seascape and rigging! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
To avoid bubbles with the AK gel, I applied it very gently with the tip of a rather small brush (round n°1). If you start dabbing it on like AK shows in their video's, it gets full of bubbles indeed, and I also don't like the look of those when the gel dries.
I take a bit of gel with the tip of the brush, apply it to the surface, and spread it around gently with the tip of the same brush. If there is any bubbles, I push them to the side of the area and wipe them away with the brush. Then, I gently dab wavelets into the gel with the same brush, more or less one-by-one. This goes a lot faster than you would imagine.
I tried quite a number of other acrylic gels before, but they all had the disadvantage of being much thicker ('stiffer'?), even the softest versions. Because of this, they retain the imprint of brush hairs which also doesn't look great close-up.
The AK gel has a perfect consistency for me: it retains wavelets but settles down just enough that brush hair marks disappear.
It is possible to thin down those other gels with water, but the mixing introduces hundreds of bubbles, with the same result as the AK gell dabbed on heavily.
I haven't found a way to thin the gels without getting a lot of bubbles.
But I thin AK did. Their gel feels to me like a thinned down version of standard acrylic gels, with water and maybe some vinegar (smells a bit like it... :) ).
But if you find another acrylic gel with the same consistency, and that can be dabbed on without getting any bubbles in, please let me know!
PostPosted: Mon Jul 13, 2020 12:23 pm
It may be worth looking into products that are not advertised as "gels", but as "mediums" and varnishes - they tend to be thinner, but are essentially the same things! The bottle labels sometimes have a sliding scale that shows you how far it is on the viscosity spectrum from thin to thick.
PostPosted: Tue Jul 14, 2020 6:00 am
Online
That is a great idea Timmy C! :thumbs_up_1:
I have only experimented with a range of gels yet, but mediums may be better indeed, or even varnishes (if they're thick enough to retain wavelet shapes).
PostPosted: Tue Jul 14, 2020 9:12 pm
Oh the whole model and base just looks great. Thanks most for showing details of your methods. Would never have tried that series of colors without seeing yours.
PostPosted: Thu Jul 30, 2020 4:12 pm
Marijn, thanks for the tip mate, I shall keep that in mind
Timmy, thanks for the tip as well!
Themongoose, thanks mate. And with pleasure, we always learn from each other ey ^^
Well, I can say the u-boot is finished. I just gave the seascape some more additional coats of Humbrol Gloss coat and with the transparant AK gel I tried to simulate water pooring from the sides, especially the bow. It's transparent so quite hard to see, but it's there.
So here are the final photos. I must say it was quite hard to get the bugger sharper and crisper on photo, not sure how though. I use my trusty old Canon 1100D with stock lens, though some photos are taken with my EF70-200 objective.
Anyway, here she is:
Users browsing this forum: No registered users and 16 guests
