It is currently Wed Nov 25, 2020 3:05 pm
PostPosted: Sun Dec 22, 2019 10:03 pm
Here is my build of the USS Haynsworth as she was in late 1962. I built her for a friend whose father served on her as a gunner on the quad 40 mm mount during the Cuban Missile Crisis. I used the Iron Shipwrights USS Henley kit for this build. I had to modify that kit quite a bit to appear as the Haynsworth. I had to remove the bases and areas where the twin 3 inch mounts were on the kit because the Haynsworth never got those. I had to modify the rear superstructure quite extensively and also the bridge area. I used the PE included with the kit and added turned brass barrels plus Veterans Models quad 40 mm mount. I scratch build most of the main mast assembly with styrene rod and some bits of the kit mast assembly. This was an enjoyable build and the kit was good quality and easy to work with.
Just finished:
1/350 USS Haynsworth 1962
Current projects:
1/720 USS Carl Vinson 2014
1/700 Hikawa Maru Hospital Ship
1/350 USS San Francisco 1944
1/350 USS Santee 1944
PostPosted: Mon Dec 23, 2019 3:26 pm
Very nice, congratulations :smallsmile: . I would also like some model from ISW, but I have not yet had the courage to buy.
PostPosted: Mon Dec 23, 2019 9:51 pm
Hi Lukas, this was my second ISW kit and both were very nice kits. They needed cleaning up and the masts needed to be scratch built but overall they were very nice kits and I am very happy with how they turned out. I will definitely be buying more ISW kits in the future :thumbs_up_1:
Just finished:
Current projects:
