Philip,
Sorry for the late reply. I had a case made out of clear acrylic by a local company (cost about Can$160.00 for the acrylic box). For the base, I used a piece of 9.25 x .75 x 54 inches stained clear pine, half inch by half inch stained balsa blocks for under the hull and the acrylic case fits over the model and base having an overall height of 14 inches. These dimensions provide adequate clearance all around (not that I'm expecting any movement). The overall package is quite heavy, however, I suspect it is lighter than a plate glass case variety. As you can see in the attached, I had a similar case for my 1/200 Bismarck.
