It is currently Fri Mar 05, 2021 6:31 pm
PostPosted: Fri Jan 24, 2020 12:31 am
PostPosted: Fri Jan 24, 2020 3:48 pm
An impressive representative of the fearsome Drengslanian navy.
Looks just like the line drawing on Deviant Art.
PostPosted: Sun Feb 02, 2020 8:13 pm
yes
drengslanian_hypothetical_battleship_by_tzoli_dce9w0t-pre.jpg [ 83.88 KiB | Viewed 395 times ]
Dračítřída class, Drengslanian Navy Battleship laid down 1909 (Engine 1911)
Displacement:
31 141 t light; 33 078 t standard; 35 061 t normal; 36 648 t full load
Dimensions: Length (overall / waterline) x beam x draught (normal/deep)
(650,08 ft / 639,76 ft) x 98,43 ft x (27,07 / 28,15 ft)
(198,14 m / 195,00 m) x 30,00 m x (8,25 / 8,58 m)
Armament:
10 - 16,00" / 406 mm 45,0 cal guns - 2 065,47lbs / 936,88kg shells, 100 per gun
Breech loading guns in turret on barbette mounts, 1909 Model
2 x 3-gun mounts on centreline ends, evenly spread
4 x Single mounts on side ends, evenly spread
10 - 5,50" / 140 mm 50,0 cal guns - 88,07lbs / 39,95kg shells, 150 per gun
Quick firing guns in casemate mounts, 1909 Model
10 x Single mounts on sides, evenly spread
10 hull mounts in casemates- Limited use in heavy seas
10 - 3,00" / 76,2 mm 45,0 cal guns - 13,62lbs / 6,18kg shells, 200 per gun
Anti-air guns in deck mounts, 1911 Model
6 x Single mounts on centreline ends, evenly spread
6 raised mounts
4 raised mounts
Weight of broadside 21 672 lbs / 9 830 kg
Main Torpedoes
4 - 21,0" / 533 mm, 20,00 ft / 6,10 m torpedoes - 1,259 t each, 5,036 t total
My modification is to reduce the length to 150 meters. The turrets come from VIRIBUS UNITIS and Elena
PostPosted: Wed Feb 05, 2020 3:51 pm
Those Drengslanians had some outstanding camouflage schemes.......
PostPosted: Wed Feb 05, 2020 10:33 pm
PostPosted: Thu Feb 06, 2020 8:16 pm
Ah - so they clearly admired RMS Mauritania's trooping paint job...
Users browsing this forum: No registered users and 26 guests
