It is currently Thu Apr 25, 2024 2:25 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Mar 28, 2011 7:32 pm
she looks good. keep up the good work!
-Abram
PostPosted: Tue Mar 29, 2011 4:40 am
The cameras working again,so here is a pic of the FM-2`s,and also one of the Hasegawa TBF`s,which took about an hour to make,the parts in my example had a very bad fit,also there were no location tabs for the horizontal tailplanes,only a vague raised part ,which was as much use as a chocolate fireguard.I think they are also overscale ,but I`ll have to check that out.
Cheers Phil
PostPosted: Tue Mar 29, 2011 2:12 pm
These are pics of the completed model,I will take some more pics when the light is better.Is the kit worth the £230 ? I don`t think so,if Hasegawa decide to produce another Allied vessel ,I shall have to think long and hard as to whether I`ll buy it.Nevertheless I enjoyed building it,and I`m please with the result .
cheers Phil
PostPosted: Wed Mar 30, 2011 12:07 pm
She looks good from here :thumbs_up_1:
Thank you Phil for the build and review, it was very informative.
Dan
PostPosted: Wed Mar 30, 2011 6:52 pm
:thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: Man Phil you are fast.
PostPosted: Fri Apr 15, 2011 8:30 pm
Outstanding build Phil! I wish I could get em done even 1/3 as fast. I would suspect that moving that fast sort of feeds on itself. The instant gratification drives one to do even more, faster. At any rate I have a question. In the photos, the hull plating lines seem to be overly thick. What are your thoughts on this, and if one wanted to sand them down a bit, is the material soft enough to make that feasible?
Again, just a terrific build! You did her proud!
Joe Dunlap
PostPosted: Sat Apr 16, 2011 1:26 am
Joe Dunlap
Hi Joe ,
Many thanks for the comments,yup ,I was tempted to sand down the plating lines,I think Hasegawa have over done them,but it may have created more problems than it solved.I have to maintain a fast building rate ,its in my nature,if I slow up ,I seem to get bogged down,which slows me up even more.It`s
a bit like riding a bicycle ,keep pedalling or fall off!!
Cheers Phil
PostPosted: Tue May 03, 2011 4:46 am
Very nice, the sea looks very good too, a dynamic presentation.
LL
In shipyard:
Trumpeter 1/350 USS Hopper DDG-70
