CSGN138 wrote:
Did the explosion destroy the port rear spy panle?
Yes. It was returned to Moorestown, New Jersey, it was repaired and installed in the Cornfield Cruiser where the FCs get their C-schooling.
Quote:
My nexy question is, if the HSS held up so good, why not build the entire hull with it?
Oh, no. How the Navy uses it, HSS is not a good material. HSS is the standard hull material. The good stuff is HY-80/HSLA-80 and HY-100/HSLA-100. HSS is better than "mild ship building steel", but it's not any good in the thicknesses that the Navy uses it (1/4 to 3/8"). At that thickness, it's garbage.
Quote:
Is HSS the strongest steel available for ship construction? I have been thinking alot about taking an ASM right into my nuke power plant, and Im thinking i really what that sucker heavily protected.
No, if you want to protect your plant, you need to use HY-100. The NGFS ships that were being proposed and designed in the 1970s were to be built with HY-100 armor. That's heavy battleship armor type material.
Quote:
Were the CGN's more protected that the NON-nukes?
Great question. The actual design specs are still classified.
Quote:
I tell you, anybody that studied the meltdown in japan after the tsunami should really be thinking about battle damage on a nuke war ship. If an ASM rips the plant open, pretty much everybody on board is screwed.
I was here for the whole thing.
Quote:
Anyway, so Ive been thinking about arrmor a lot lately. If I were to use HSS for the whole hull, what kind of weight would i be looking at?
There's really no change. The whole hull of the DDG-51s is HSS, and the Cole was still super broken.
Quote:
How would a double hull change things up. I'm thinking the kind of tonnage not seen since WW2. Nobody does that anymore, but who cares. I want thins ship to be able to take the fight right into the enemies face, hit hard, take damage and win the fight.
Do what I did. After all kinds of designs...I discovered all I needed to do was slightly later a WWII combatant design. Chose a CLAA, CL, or CA hull that is about the right size and develop a super structure on top of it. Those ships were designed to take hits, and a Cleveland-class CL could take way, way heavier hits than a DDG-51. A Baltimore, Oregon City or Des Moines-class CA could take many times the damage a DDG-51 or CG-52 could. My "modern day heavy cruiser" carries an Aegis-like AAW system, but it it is built on a slightly modified Des Moines hull.
Keep it coming, man!
