Russ2146 wrote:
. Seems to me that if beefing up the mounting will allow you to use a RAM launcher capped with a SeaRam radar and be switchable from remote to mount control, that is the way to go.
This post is getting long so I'll stop now.
Have you ever seen this?
This was a proposal back when they were first mounting RAM on ships, so they figured they could put 2 RAM launchers on a 5inch gun mount.
The thing with the hanger was that since Kentucky is at the 2nd deck, you could continue to complete her up in the shape that the Vittorio Venetos were, completing the stern only up to the first deck and making it a helo deck with the hanger underneath the guns of Turret 3. Some sort of spacer would be needed to raise the height of the top of the barbette up 1 or 1/2 deck for sufficient clearance, but I think that should be feasible before installation of the turret itself.
As you can see in this picture:
My comment about the Italians was that their VVs were perfectly arranged for this. All that was needed was to build the hanger, and they would have been good to go. Since you're building up your Kentucky from the 2nd deck up, she should be able to accommodate such a design change
