It is currently Mon Jun 23, 2025 7:35 am
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Wed Mar 06, 2013 1:49 pm
Cliffy B wrote:
Aircraft:
3 SH-3 Sea Kings or
4-5 SH-2 Sea Sprites or
a combination of both
Suggestion: presumably the primary reason for this conversion is to keep the 8" guns in fleet service, ergo these ships would likely deploy with the amphibs.
Outfiting her with USMC aircraft (UH-1s and possibly AH-1s) might make here a potent advance force ship.
PostPosted: Thu Mar 07, 2013 5:29 am
SumGui wrote:
SMARTROC:
ref: Sumerall, Robert F; Sumner Gearing Class Destroyers, Their Design, Weapons, and Equipment, pg 142-3
"SMARTROC was a means of providing destroyers with a heavy shore bombardment/surface attack round that could be delivered with precision accuracy. The Naval Weapons Center (NWC), Dahlgren, developed the unique and inexpensive weapon during the Vietnam War, using existing technologies and weapons systems. SMARTROC consisted of a Mk82 laser-guided bomb projected by an ASROC booster from the Mk112 launcher. The program was originally called SMARTAS, a derivative of smart bomb (Paveway) and ASROC. The acronym was changed to SMARTROC for obvious reasons. A mark number (Mk) was never assigned..."
I won't reproduce the entire section here, but the numbers:
Two phases:
First Phase 72-73, using existing rocket motor and parts - 10,000yd (5nm) range, same as an ASROC round.
Second Phase 75-78, improved rocket motor and improved airframe (still fit in Mk112 box). 24,000yd (12nm) range
Tests seem to show approx. 20ft accuracy, for both, same as Paveway.
The mentioned reference also has information about Sea Chaparral, Firebee, DASH, Weapon Alfa, RAT, and SOB (Shrike On Board). An outstanding reference which I cannot recommend enough.
It has the only references I hold on SMARTROC, and SOB. It holds the best references I have to RAT, Weapon Alfa, DASH, Sea Chaparral, and the electronics fits of the late 60's-early 70's. It covers the FRAM processes, which can also help envisioning your conversion. I wish there was a reference like this for the conversion of the CGs...
(SOB was Shrike added to Gearings used for Shore Bombardment in Vietnam, with the intention of being able to respond to shore targets illumination the bombardment vessel. Four weapons were added to the top of the Mk112 box in a basic frame, and elevated and trained with the ASROC box. Installed in 10 Gearings from May 72 to Oct 73)
I mention these because they may have a bearing on how you might arm a 1972 version.
SMARTROC is on an early version of a shore-bombardment enhanced Spruance I intend to build - with SMARTROC and ASROC mixed in the magazine - along with the Mk71. Probably the Hayler DDH version, and a this be the first to get the ABLs in my altered timeline. Sounds to me like that is a near match for the roles you have for your build. (Of course, Laser guided 203mm rounds may make the SMARTROC less relevant...)
I also thought a SMARTROC equipped Knox might be reasonable for a get in close bombardment platform with the Mk42.
Basically, I love the SMARTROC idea - anything with an ASROC box becomes a potential bombardment platform.
They could have called it SMARTAS(P) as in Anti surface (Paveway) I would have gone with SMARTASS.....
CGN9 could have used this weapon with multiple reloads (And a mast mounted Laser/FLIR on top of fwd mast) would have been a serious shore bombardment weapon. A mk2 or 3 version with improved booster and 20nm range would have been NASTY.
Great looking ship !! If you think about a hanger it is only the flight deck, elevator mechanisms and supports that are the heavy items, the sides are relatively thin (compared to the flightdeck). And if built using the same techniques as the Albany rebuilds (lots of light alloys...) might not be as heavy as it looks.
Cheers Bruce
PS I have something similar drawn on paper.....only for a somewhat larger model!
building:
1/72 RC USS LONG BEACH CGN9
1/72 RC USS CALIFORNIA CGN36
1/72 RC USS SAIPAN LHA2
1/72 RC USS SHARK SSN591
1/72 RC USS SEAWOLF SSN21
1/72 RC USS ALBANY CG10
PostPosted: Thu Mar 07, 2013 1:53 pm
SMARTAS :big_grin: What a riot that would have been.
I agree, an upgraded extended range version would have perfect!! Too bad.... Any idea what the laser designator/FLIR would have looked like? I'd love to make a 1/350 version someday to go alongside my CVHA design. What a great looking pair they'd make! 1/700 first though. Have to iron out the kinks first :thumbs_up_1:
Heard anything about Lockheed's POLAR bombardment rocket? It was an adaptation of the Army's MLRS rocket. Can't find any real concrete specs other than that it was under 300nm range and could be quad packed in VLS like the ESSMs. It lost to the LASM in the contest and we all know how that fell on its face... POLAR sounds like it would have been a wonderful augment to TLAMs and guns if for nothing else than its size!
Precision Over the horizon Land Attack Rocket
https://mfcbastion.external.lmco.com/missilesandfirecontrol/our_news/factsheets/factsheet-POLAR.pdf
Busto, I designed her primarily as an ASW SAG flagship but with the large hangar and flight deck a secondary role of USMC support is a given. I figure her place would be right at home providing ASW support to an ARG during transit and then shifting to fire support while still maintaining command and control over the ASW picture as well as extra helos while the cans go hunting. That being said, if the mission called for it, she could be loaded with Marines and their birds and act as a mini LPH as well with plenty of extra room aboard for them.
Thanks for the support guys, she's moving along. Hope to have another update this weekend after I start detailing the hangar bulkheads.
PostPosted: Thu Mar 07, 2013 3:11 pm
POLAR was discussed a little on page 4/5 of the modernized DDG-51 Flt 1 thread:
viewtopic.php?f=67&t=64665
Contains the same link you posted above. Discussion there may/may not add anything.
PostPosted: Thu Mar 07, 2013 4:18 pm
Geee....and I asked you about it then too and completely forgot about it afterwards..... don't mind me :wacko:
PostPosted: Sun Mar 10, 2013 4:16 am
Great looking progress, Cliffy!!! I really can't wait to see more!
PostPosted: Tue Mar 12, 2013 4:10 am
Are there any updates on this? :D
PostPosted: Tue Mar 12, 2013 10:31 am
Yes there are...just didn't take the photos yet! Got the hangar deck bulkheads (fore to aft) assembled and glued on. Needs a coat of putty then I can start measuring for the interior spaces. Had to wait for the bulkheads to go on since they dictate the sizes of everything inside. I'll be using some 0.25mm or smaller strips to do the interior details and then glue them onto the main bulkheads after I paint them and the deck. Need to order a set of decals though I think before I install the detail sections. Still need a 50 star US flag for Turret 2. Have any tiny ones Dave?
PostPosted: Wed Mar 13, 2013 8:19 am
Slacker!!!
Not really. I might. I will get back with you over the PM.
So...how about those pictures?! :D
PostPosted: Wed Mar 13, 2013 8:51 am
