OK, Im jumping in with this submission. I have to wait on kits for my CSGN-138 project.
I was always fascinated with the Fletcher class. They were great little fighters. So I thought why not try to recreate that in a modern ship. I had an Academy Perry class that i never built, so it is my donor.
I'm designing this ship with anti-piracy, anti-swam attacks, fire support , anti-shipping, and anti-sub operations in mind.
Systems will be, and any suggestions willl be considered:
2 Mk-45
2 OTO 76mm
4 Oerlikon Millennium 35mm (Possible)
2 Phalanx CIWS Block 1B
Not sure on smaller Crew fired weapons, Y'all can help on that
64 Cell MK-41 VLS
Mix of ASROCK, ESSM, and TLAMS
8 × RGM-84 Harpoon missiles
2 × Mk 32 12.75 in triple torpedo tubes
Sensors and electronic warfare
SPS-49 with a leaning toward SPS-40. Not sure you would need a 440 mile 2-d air search capability with this ship
SPQ-9b
Not sure if you need directors with the SPQ-9. I need some info on that
Sonor will be the same the OHP's had minus the helo.
SLQ-32
Ok, thats what I have so far.
Most of the parts are only mocked up right now. I have a lot of filling and sanding in my future. I will probably move the Mk-141's as i dont know how the would like being that close to the funnles, and the VLS will be turned 90 degrees when finished (only sitting like that for illistratin)
So far i have learned that I'm FAR from as good as most of you guys and i hope my feable attempt is not an insult to you guys. At this point, I'm thinking of putting my CGSN-138 on hold so I can learn some skills first, so that I might be able to do it justice someday.
Anyway, I'll keep hacking at this thing and post updates when i make progress.
Thanks for looking!
Joe
