It is currently Wed Jan 20, 2021 8:58 pm
Post new topic Reply to topic  [ 741 posts ]  Go to page Previous  1 ... 34, 35, 36, 37, 38  Next
 Post subject: Re: HMS Prince of Wales
PostPosted: Sun Mar 15, 2020 8:09 am
Well, I have received the Colourcoats paints of the appropriate colors and am starting the model. I assume the steel decks were a dark grey but is there a particular shade of grey designated?
Walt
PostPosted: Sun Mar 15, 2020 10:50 am
To me, the photo's taken at Scapa look like unpainted wood decks!
However other photos at other times indicate dark Gray. Your choice 507A or MS 2 or MS 1, are all possibilities.
Your model your call!
hth
John
PostPosted: Sun Mar 15, 2020 12:43 pm
I was referring to the steel decks- not the planked decks.
PostPosted: Mon Mar 16, 2020 1:24 pm
I meant the steel decks, were likely painted 507 A, MS 2 or MS 1 in that timeframe.
"Dark Grays"
I was just pointing out her wood decks were unpainted at the time of that photo series.
PostPosted: Mon Mar 16, 2020 3:56 pm
Thank you sir
PostPosted: Wed Apr 22, 2020 2:23 pm
I've seen several models and pictures of Prince of Wales, and each seems to show different paint schemes for her ship's boats. Were the hulls camoflage colors as the superstructure/ Were the decks gray [grey], natural wood? Were the upper works, cabins white, camo or some other color? Thanks.
Walt Haynes
PostPosted: Sat Apr 25, 2020 2:25 am
Its been a while but I am now working on repainting the Prince of Wales kit I had after carefully stripping the initial paint and repainting with the new revised colours. I hope I am doing the right thing.
PostPosted: Sun Apr 26, 2020 7:11 pm
Walt Haynes
Its a black and white video but the keel of the boats appear to be white with the tops white and decks possibly teak. https://www.youtube.com/watch?v=DqfHbu6o7HU
PostPosted: Tue May 12, 2020 2:07 pm
Excellent Effort Sutho!
Thank you for showing us how the new Colorcoats look on POW!
PostPosted: Sun May 17, 2020 2:34 am
Thanks I will post some more photos soon. It is well on its way to being finished. If it were not for those revised paints then I would not have believed that the colours were credible. My only guess was that WEM probably believed they had the correct paints in good faith but I suspect got samples from paint that had spoiled somewhat by going yellowish.
On another note I am trying to figure out the rigging diagram for Prince of Wales and posted in the Battleships KGV fan section if anyone can help me.
PostPosted: Sun May 24, 2020 7:53 pm
Its not finished yet but making progress. Still got to clean up some finer details and make some adjustments here and there.
PostPosted: Mon May 25, 2020 6:28 am
SovereignHobbies
SovereignHobbies
How do you feel about it?
I've made a little more headway on my own 1/700 scale effort recently. I also updated the drawing above to show the individual gun barrels and the turret roofs.
James Duff
Sovereign Hobbies Ltd
Current build:
HMS Imperial D09 1/350
PostPosted: Mon May 25, 2020 6:52 am
Paint can easily be adjusted this early on. The rigging is proving to be a headache as it appears different to other KGV ships.
The Pontos detail up kit is rather interesting. It has very good instructions however there are photo etched parts included in the POW set that are not listed on the instructions such as that scupper on each side of the ship. There also appears to be a boom attached to the ships hull proven in photo images. I had to improvise with parts in the Pontos kit that did not appear allocated to use.
I could imagine 1/700 would be extremely difficult. It is bad enough as it is with extremely fine tweezers trying to put some extremely small photoetch parts on a 1/350. With a bit of luck by the weekend I may have it completed to a degree I am happy with.
The video below is going to give people a headache. The bottom right corner appears to indicate completely broken up colours. Perhaps a paint job or primer or colours being altered at the time of filming.
PostPosted: Wed May 27, 2020 9:51 am
I checked the video and that contrast puzzle is on all frames, but none of the photographs...
PostPosted: Wed May 27, 2020 12:04 pm
Are you referring to the two areas I am pointing to in red here?
If so it looks to me that it is just a reflection off the near-horizontal top of the external armour belt?
I would say the same colours as you see above extend downwards onto the armour belt uninterrupted but just look different due to reflection off the near-horizontal top of the armour belt when the rest of the colour is vertical.
PostPosted: Wed May 27, 2020 7:51 pm
Yes I am, thanks. It has been one of those ongoing issues about this ship that makes it so difficult to recreate.
PostPosted: Sun May 31, 2020 11:35 am
If it were me I would apply the camouflage as normal. The highlighted bit seems to me to be just a reflection with no bearing on the overall camouflage scheme. I certainly would not think it is a different colour or anything like that.
PostPosted: Thu Jun 04, 2020 5:43 am
Sovereign Hobbies have now published an updated graphic showing HMS Prince of Wales' December 1941 Camouflage scheme:
https://www.sovereignhobbies.co.uk/pages/british-royal-navy-colour-schemes
Which should be helpful to anyone modelling HMS Prince of Wales.
PostPosted: Fri Aug 07, 2020 3:28 pm
Hi
I'm trying to wrap my brain around the 507 A/B thing. I've understood that they were practically the same colour, insofar as some posts here have said they were identical (Sovereignhobbies for one).
I'm currently working on HMS Kelly, and I have POW in my stash. Christopher Langtrees book "The Kellys" say that HMS Jupiter had a three tone camo in 1940 of 507A, B and C. This picture is from that book.
To my eye these are three distinct colours, which makes me all the more confused. More distinct than in the table near the bottom of page 35 in this post.
If I'm to make a few guesses, this apparent difference might be because one of the colours had enamel, changing the glossiness? I'm honestly struggling a bit, and can't figure out which colour tone to use for Kelly, which is listed in the book as 507B all over as of 1940.
Thanks for all your help.
Previous: 1/700 HMS Campbeltown
Building: 1/700 HMS Kelly
Waiting: 1/700 HMS Naiad (or Dido), HMS Prince of Wales
PostPosted: Fri Aug 07, 2020 3:55 pm
Both 507A and 507B were the same shade: Home Fleet grey. 507B was a harder wearing paint because it contained enamel. But this made it glossy (and hence shiny) which was a disadvantage in wartime. The use of enamel in RN paints was officially discontinued in October 1940 but the use of matt surface paint was reported as 'the rule' by 18th December 1939 . On Jupiter in that photo you are probably looking at black, Home Fleet grey (507A) and Mediterranean Grey (507C).
(Re Langtree and Kelly in 1940, it rather depends exactly when you are referring to, but often where Langtree suggests 507B on 5DF destroyers in later 1940, they were actually in Mountbatten Pink.)
