It is currently Sun Jul 13, 2025 6:44 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
PostPosted: Sun Aug 16, 2009 1:51 pm
As a huge fan of the „age of uncertaincy“ I for long wanted to build a model of the „Popovka“ Novgorod, the first circular ship built by vice-admiral Popov in 1872-1874 for the Imperial Russian Navy. The plan of the ship is from Dirk Nottelmann (https://www.shopssl.de/epages/es119126. ... ucts/WI-30) and shows the ship as well in her first appearance as in her last days.
A modelling-comrade of mine, Lothar Wischmeyer, did the Novgorod a few years before and lend me his great silicone forms. The master was turned from beech-wood, the form was of quite thick silicone-rubber on a clay bed to avoid warping of the form.
The form was first coated with a release agent, than a layer of gelcoat was plastered on the form. After the gelcoat did set for about two houres I slathered a paste of 50 percent resin and 50 percent glass fibre pieces on the sharp-edged or generally difficult parts. Than three layers of 160 g fibreglass-mats were laminated with a good amount of resin in each of the forms. After complete drying the hull and the deck were taken out of the form.
I was very pleased with how it came out. Post-treatment of bubbles was quite limited.
As all my models the Novgorod should be radio-controlled. I decided to motorize only the two outer of the six propellers. For these I bought ([url]http://www.mz-modellbaushop.de/]/url]) brass-propellers. The four inner propellers are only dummies cast in resin with a galvanic copper plating. The ship is steered only with these outer propellers, the rudder ist fixed in a middle-position (according to reports of the original ship the rudder there was almost useless). Both propellers are propelled by 6 V motors. These were powerd by a 6 V 7,5 Ah accumulator.
The Opening for maintaining the electronic is placed under the forward superstructure and the barbette.
The forward superstructure was made mainly from 0,5 and 1 mm sheet-styrene. The outer hull of the barbette has a diameter of 90 mm and I had the problem that I couldn’t get some 90 mm tubes of any sort, so I made the walls of the barbette from resin soaked paper wrapped around a circle from sheet styrene. The ring that remained when I cut out the circle was placed at the upper part of the paper ring while laminating the paper strips. It was later removed. The inner hull of the barbette was made from a tube with an inner diameter of 70 mm. Both were connected with a ring of 1 mm sheet styrene.
The holes for the bulleyes were drilled and the two funnels were installed. The lower part of the funnel was a resin casting of a master turned by Lothar Wischmeyer. The long straight upper part is again made from resin soaked paper over a styrene sceleton.
The big vents were also casted from a master by Lothar Wischmeyer that I altered a bit until it fitted the vents in the plan.
The guns are turned parts from Lothar Wischmeyer, for the sides of the carriage I made a master from styrene and again resin soaked paper. The rails are cut with a circular-cutter from 0,5 mm sheet styrene, two slightly wider rings for the base of the rails and two narrower rings to be placed on the wider rings.
The levers, wheels as well as the top of the ammunition-duct are foto-etched. The grid at the sides of the carriage are from a foto-etched-grid I bought at MZ-Modellbau. The frictional compressors were made from 0,3 mm sheet styrene.
The rudder with it slightly complicated shape I made also from four foto-etched parts which I soldered.together. Same are the mountings for the lifeboats and the skylight on the afterdeck (the lower part of the skylight is again made of sheet-styrene).
At the first time on a rc-controlled model I wanted to add some depth through the painting of the model. Usually rc.controllrd ships get – due to the Naviga-reglement a plain, new looking finish, but this time the segmented deck secuced me to try something different. First I engraved the segments, preshaded the grooves between the segments black. Than a thin layer of gmedium grey was airbruhed o the whole thing followed by a lighted up layer on the middle of segments. I really like who it looks. The effect is decent but gives still a lot of depth to the otherwise somewhat boring deck. The only disadvantage is, that you have to use this technique on all parts of the ship to make it look right, thus giving lot more work on the painting front.
For the under-water hull I used a tapping technique with a very short brush. The original hull was copper plated but with very small plates. As I was not keen on glueing thousands of 2 X 2 mm brass-bits to the hull, this gets very close to the original look.
Also for the first time I used wire-end sleeves for the bulleyes. As I had only tinned sleeves I got them a galvanic copper plating (today I found gilded wire-end sleeves in the car-hifi-corner of a electronic shop, so the galvanic plating won’t be necessary any more). For the glazing I punched out little bits of a clear rubber like plastic with a pair of punch-pliers. These fit perfect in the sleeves.
The lifeboats were resin castings by Lothar Wischmeyer. They were fitted with a grating and benches from 0,3 mm vermeer.
Some pictures of the finished model:
The seagoing qualities of the model are quite authentic, which means not sooo good. The ship is very good at turning. Unfortunatly it requires quite a lot of training to go in a straight line (and even than it looks like the helm had more than a healthy quantity of his vodka ration). But because of this it is very funny to steer it.
And last but not least a video of the ship on the water:
http://www.smc-wuppertal.de/Schiffe/Novgorod/Bild%20028.avi
PostPosted: Sun Aug 16, 2009 11:39 pm
:thumbs_up_1: I like this. The resin castings look like they came out really nice as you mentioned.
I'm waiting for the video link to load out of curiosity.
TommyL.
PostPosted: Mon Aug 17, 2009 2:53 am
Online
That is REALLY impressive- workmanship is of highest quality- and it really enthuses me for the Popoffkas ...all over again!!
EXCELLENT methodology--Thanks for showing it here!
JIM B :thumbs_up_1: :thumbs_up_1: :wave_1:
PostPosted: Mon Aug 17, 2009 10:44 am
Hehehe - it's so cute running on the water. Looks like a big tadpole, with the funnels for the eyes and the wake for the tail :big_grin:
This is top notch workmanship , very impressive indeed and a subject with such a rich history . :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
PostPosted: Mon Aug 17, 2009 3:40 pm
Indeed, that's a fine build!
PostPosted: Tue Aug 18, 2009 7:54 am
Really cool made!
New Ships Planned For Shipyard:
USS.Missouri 1.545 scale to new jersey desert combat
Ships in dock:
USS.Saratoga 1.535 scale Desert combat (currently on hold)
Ships in repair:
SMS Tirpitz 1/540 (adding new radars and fixing the main guns)
PostPosted: Tue Aug 18, 2009 10:41 am
Ingenious techniques. Very well done!
PostPosted: Thu Feb 17, 2011 1:57 am
Completed
PostPosted: Thu Feb 17, 2011 6:07 am
Impressive :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
PostPosted: Thu Feb 17, 2011 6:34 am
i love it - fantastic :thumbs_up_1: :thumbs_up_1:
PostPosted: Thu Feb 17, 2011 2:09 pm
http://www.smc-wuppertal.de/Schiffe/Novgorod/Bild%20028.avi[/quote]
This is fantastic!
:woo_hoo:
:thumbs_up_1:
MUSEUM OF BALTIC SEA
http://temnikoffv.wix.com/museum-of-baltic-sea
http://www.hot.ee/revell/
PostPosted: Thu Feb 17, 2011 3:06 pm
Being round ,how could anyone tell which way it was going or was that the idea ? :huh: Great job on something realy different . :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
PostPosted: Thu Feb 17, 2011 3:20 pm
http://en.wikipedia.org/wiki/Russian_ba ... p_Novgorod
PostPosted: Thu Feb 17, 2011 5:37 pm
Thanks for the education :big_grin:
PostPosted: Fri Feb 18, 2011 1:07 am
I''ve always been intrigued by this ship. Thanks for pulling it out into three dimensions! A fine, fine build :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
This is also the first time I've heard of resin soaking paper for hard-to-reproduce items. Could you describe how you did that - what kind of resin, paper, etc? I'm itching to try that!
dave
Time flies like an arrow. Fruit flies like a banana...
Groucho Marx
PostPosted: Fri Feb 18, 2011 3:13 am
It looks pretty good indeed!!
One of your props seems to be cavitating big deal.
That could destroy it in not all too much time.
Cavitation can be seen because of the bubbles behind the prop.
Cavitation is water starting to boil because of low pressure at the suction side of the prop.
As soon as the pressure rises again at the other side of the prop the bubbles caused by the boiling water implode releasing quite a lot of pressure, which can damage the prop and anything else in the area.
I don't know how you can solve this problem, having it turn slower does help.
If you want to be able to maintain topspeed you'll need to try adjusting the blades carefully and test when the bubbles are gone.
Greetings Josse
Making a complete new Well Enhancer, again scale 1:75.
PostPosted: Thu Feb 24, 2011 1:18 am
Not really. It's just because the props are only a few milimeters
underneath the water surface. As you can see in the pictures the ship is
propelled with two bell-shaped rotor motors. These are usually
slow-runners. With those it is absolutly impossible to get an
cavation-effect (unless of course the prop get's partially out of the
water - which may happen depending on waves - but that would result in
hyper-cavitation). Cavitation can appear at the propellers of RC racing-boats, where it lowers the speed of the boat. On the other hand hyper-cavitation is sometimes an appreciated effect (created by hydro-props that are only half-immersed) because it reduces the friction of the propeller.
Lord, no! That's a model-making-legend. Cavitation may cause destructive problems
with real-size propellers but not with the propellers of our little
ships. The bubbles and as a result the implosion-jet are just too small
to have any effect on the propeller's surface. It may cause a decrease
of effectiveness of propulsion but as far as propulsion ist concerned
cavatation is the most minor problem concerning a round ship without an
effective rudder.
PostPosted: Thu Feb 24, 2011 1:44 am
Great build, I've always been fascinated with the round ships. Wish I had those molds!
PostPosted: Thu Feb 24, 2011 3:19 am
Hello!
Me the information on the ship Vice-Admiral Popov interests.
Who can help?
It is better to worm his way in the tail of the professionals than to soar above the kettles.
http://www.modelshipgallery.com/gallery/users/Alexey-Nikitin/user-index.html
