Timmy C wrote:
Not a good photo for comparison, Gaston - the photographer was clearly some height above the main deck, given that you can see the top of turret three. Furthermore, the line you drew cuts across the middle of the deck bollards, meaning your line does not accurately trace the deck curvature, EVEN IF the photo had been taken exactly at deck level!
Actually what was wrong was not so much with the photo but with the drawing's coloured lines I added, and the way I drew the red line to match the bottom: The drawing is depicted quite stern-up, and that does exaggerate the "perking up" of the tail: I tried to match the keel angle more precisely this time around, and with a better comparison picture as well...
The red line (in the drawing) is now quite precisely level with the keel (with calipers). On the real ship photo, it is pretty close to level with the black painted line, which does match the keel on the real ship (I had to elevate a bit from the black line towards the front, as the viewing angle is not entirely centered: This compensation of mine
reduces the difference with the drawing):
Even with all these precautions, the drawing is actually pretty far off "character": It doesn't even have much freeboard emphasis at the front for cutting waves at the bow (unlike what the real thing displays prominently): Despite the corrections to allow for the tilted drawing image, and the not-perfectly-square photo, the drawing still looks a bit like the ship wants to go both ways...
Yuk.
Gaston
